what should i do to my Walkera #60
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> what should i do to my Walkera #60
Page: [1]
Login
what should i do to my Walkera #60 - 3/2/2007 5:26:05 AM
elva-sisu
Status: offline
I recently purchased a, Walkera 60# 7CH 3D CCPM RC Electric Helicopter Brand New Design Metal Main Frame. after charging the battery I plugged the battery back in. With the throttle all the way back, the motor started spinning as soon as the battery was plugged in. The throttle will not reduce from full speed.
After about 10 minutes of operation the throttle stuck wide open and will not respond to the trasmitter controls. Please advise me of what to do.
       Post #: 1
RE: what should i do to my Walkera #60 - 3/2/2007 6:27:38 AM
NITRO_VEEDRIVER
Status: offline
please see the thread called walkera 60. its very helpful....
_____________________________
You can run, But you can''t hide!
(Dwayne (Dog) Chapman)
(in reply to elva-sisu)
       Post #: 2
RE: what should i do to my Walkera #60 - 3/2/2007 7:55:42 AM
GravityWorks
Status: offline
read the manual... over and over again, check all the dip switches on the radio, then read the manual again. also check the red button on the ESC, your motor should not turn on until you press that button. is it stuck?
(in reply to NITRO_VEEDRIVER)
       Post #: 3
RE: what should i do to my Walkera #60 - 3/2/2007 9:16:31 AM
gj1803
Status: offline
I would definitely check your ESC. You should be able to plug ur battery in with your tx throttle on and your ESC should not let the motor start until you have reset your TX to throttle off.
GJ
(in reply to GravityWorks)
       Post #: 4
RE: what should i do to my Walkera #60 - 3/2/2007 5:05:38 PM
ALMISHEA
Status: offline
Make sure your DIP settings on the back of your Tx are correct. The same thing happened to me. The manual will tell you what they need to be at. It sounds like the throttle switch is reversed. Mine went like a rocket to the ceiling and took out a light fixture.
       Post #: 5
RE: what should i do to my Walkera #60 - 3/3/2007 3:48:09 AM
JSGP51
Status: offline
Just a thought. Maybe your inverted flight switch is in the down position. Which would make the htrottle go full bore when pluggedin, Yes????
My 22e did that when I first got it and did not know didly. Thank god I did not hurt myself nor my furniture.
(in reply to ALMISHEA)
       Post #: 6
RE: what should i do to my Walkera #60 - 3/3/2007 4:04:42 AM
freddysatellite
Status: offline
Yes - check the switch on the top right of the transmitter- it should be in the "UP" position.
(in reply to JSGP51)
       Post #: 7
RE: what should i do to my Walkera #60 - 3/6/2007 9:35:10 PM
MFLOOD3800
Status: offline
I would check the esc and see about its programing, or the tx dip switches. if it were the idle up switch it wouldnt have positive pitch in the blade to lift but it would sit there and run wide or close to wide open . It sounds like idle up switch for sure or the esc wasnt properly programed and it fired up with throttle stick position in wrong direction.
Did you try moving throttle to full up while it was winding up?
(in reply to freddysatellite)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU5
