1320 mAh in a T-Rex
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> 1320 mAh in a T-Rex
Page: [1]
Login
1320 mAh in a T-Rex - 3/2/2007 2:45:38 PM
techrtr
Status: offline
Can you fly a T-Rex 450 with a 1320 mAh battery. I'm just setting one up and already have a couple of 1320s. If I can putz around with those for awhile before I go out and buy 2100s it would be nice.
< Message edited by techrtr -- 3/2/2007 2:46:02 PM >
       Post #: 1
RE: 1320 mAh in a T-Rex - 3/2/2007 2:48:04 PM
BarracudaHockey
Status: online
Dont know what kind of flight times you are going to get I was getting 8 minutes safely with 2100's
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to techrtr)
       Post #: 2
RE: 1320 mAh in a T-Rex - 3/2/2007 2:55:50 PM
ct420
Status: offline
It should be possible, in theory, but will depend greatly on your setup.
As long as the current draw from the motor does not exceed the 'C' rating of your battery, it will work...
(in reply to BarracudaHockey)
       Post #: 3
RE: 1320 mAh in a T-Rex - 3/2/2007 8:51:09 PM
Missileman
Status: offline
Depends on what type of flying you are doing and your setup.
I am only doing slow forward flight and hovering with stock motor, pheonix ESC, hs56 servos on the collective, 9650 on the tail and a JR 410t gyro. 1320 get me around 8 minutes or so.I would imagine if I was flying more agressively the flights would be much shorter (but so would my nerves)
Comments by author are not to be confused with the truth, past or present.
(in reply to ct420)
       Post #: 4
RE: 1320 mAh in a T-Rex - 3/2/2007 10:00:06 PM
techrtr
Status: offline
I just want to test the setup of my radio and linkages, maybe hovering and gentle forward flight. I'll wait until I have some 2100s before I go crazy with it.
(in reply to Missileman)
       Post #: 5
RE: 1320 mAh in a T-Rex - 3/3/2007 12:13:50 AM
KamikaziRcPilot
Status: offline
I started with 1320's because I already had several of them used in other aircraft. They're ok for basic hovering and simple forward flight at lower headspeeds (2300-2400), but you'll abuse them it you try much more. When I got to the point where the packs where approaching 130F at the end of the flight because my flying was becoming more aggressive, I started purchasing 2100 packs.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU5
