sean sweeney
FL, USA Status: offline
janmaxx, To get the most performance from the Byron fan with out a cheater hole your intake will need to have the same area as the fan itself. With the F-104 then, each intake would need to be a half circle of 6" diameter. If the body of the car your building is not that big, then you will need cheater holes to get the extra air into it, otherwise you will not get enough air to feed the fan. If you put the cheater holes on the bottom of the car then you will have a great vacume cleaner for the track too! (fan life will suffer though) To mount the Hacker motor you need the adapter that Electric Jet Factory sells, its about $35. Sean
