Slo-V Flyer
TX, USA Status: offline
Hi, I'm hoping some nitro gurus can help me out here. I've tried to search for another thread that might help me but most of them don't discuss the problem I seem to be having with my Pro .15 that I run in a 14 year old Nitro Hawk (it's funny how unexpectedly old plastic parts break...). I've bought the engine last November, '06. I've got some experience with nitro from before when I had a Cen MT2 and the .16 it had. I've read articles on tuning nitros and such, I broke the Pro .15 in like the manual suggests, about 6-7 tanks to be safe (ran it through different speeds gradually leaning it 1/8 turn or so, waited 5-10 minutes down before next tank). I run it with a blue 360 Stinger pipe (nice and loud!! Plus it looks realistic sticking out the rear bumper) I'm pretty good about watching the temp and keeping it below 250'F. I've recently realized I could lean the LSN another 1/4 turn so it was nice and peppy and crisp sounding at the low rpm end, as well as keeping the blue smoke streak at high speed. My problem started a couple days ago, I was running it and I cartwheeled my Nitro Hawk a few feet after hitting a curb. Since then the engine's not behaving normally. Meaning, I'll be running it, and suddenly I'll notice it'll lean up and almost pull a wheelie hitting a small bump, or I'll come around and gun it, and the engine will act "rich" and slowly get up to full speed, as if it was lacking air and fuel altogether. I've ran it about 4 times since then and each time it seems it will randomly change its behavior. The other day it started blowing extra smoke , but then leaned out itself (reached 270+'F) to where I had to richen it almost another 3/4 turns (which is unusual because I always run it between 2 & 1/4 and 2.5 turns out for HSN depending on weather and around ~240'F). Then next time it ran "normal" so I had to re-lean the HSN back to ~2.5 turns out. I've already taken the engine apart, cleaned out the tank, switched out the fuel line with a longer direct (w/o filter) feed to test it, removed the carb and checked it for junk/broken or needles (cant see anything wrong there either), washed out the air filter and oiled it again, visually checked inside the engine case for anything "unusual" (nothing). Basically it's running mixed between rich-, then lean-ish next moment, all with a full tank of gas so I know it's not the low level of fuel sloshing and creating bubbles in the fuel flow, YET I notice that when it starts to run erratically, the fuel line (I run a filter which I triple checked for dirt) has "bubbles" or empty space between fuel as it's feeding into the carb. I can't remember if it did that before I started having this problem, but it seems the rpm rises as the bubbles travel to the engine (obviously it leans out a little with those "bubbles" . Only other thing left is besides taking it to the LHs nitro guru and dishing out $$$ is replacing the pressure line that runs from the pipe to the tank and see if it's clogged (it's opaque so I can't see dirt in it like my regular blue fuel line). If you haven't fallen asleep reading this, well then do you have any experience with this kind of problem. I'm on a budget so I cant just replace it with an OS engine like some of you are eager to suggest. Besides, when I have it running right, it's a screaming little engine, fast enough for the old timer Hawk. Thanks! Edit: I just tested the fuel tank for pressure, and it seems the cap is sealing off well (I blow on one end of the tube and I have to open the cap to even let air go through) so I don't think the cap's seal is the problem. I'm thoroughly puzzled.
< Message edited by Slo-V Flyer -- 3/3/2007 6:40:29 AM >
_____________________________
Emaxx+Feigao 7XL+full CVDs, Bandit+GTB 3.5R, Rustler+Feigao 9L, TC4+Mamba 5700kv, Mini-T+Mamba 8000kv, Recoil+3800kv, 3s lip
