Prop Nut
MI, USA Status: offline
I have been doing a little more work. I try to keep the W word to a minimum though I built the rudder using the laminate system, wrapped around a jig: I wanted to install the control horns, 1/16th ply hardened with thin CA, after I cover the surfaces so I constructed the elevators with hardwood slots for this purpose: The fuel tank is mounted on a removable hatch, I thought this would be a good idea if I wanted to rework it later for smoke. Easy access is always helpful: I roughly copied Del's excellent tail skid system from his 1/3rd scale DR1, the wire and bungie are temporary, I have an idea that for a retainer that I need to work out on the mill and lathe made out of Aluminium. I also have rubber bands (see them on the landing gear? Scroll up for those pictures) that I will use here. Speaking of the landing gear, if you scroll up you will see my Balsa USA 1/3 scale kit wheels. These are steel rims with rubber hoses joined by glue. They are excellent. I then covered both sides of the wheels with Super Coverite and CA glue. For a FunScale project like mine they look pretty good. I am not sure if Balsa USA is still selling this kit but for 29.00 it was a very good deal. This evening, after I get some of that pesky real work done (darn customers), I hope to get a little more finished on the Triplane. Wish me luck.
< Message edited by Prop Nut -- 1/21/2008 7:24:55 PM >
_____________________________
Scope? Listerine? Or Prop Wash?
