RE: RC Surfer    Gallery
Logged in as Guest
Users viewing this topic: smithcreek
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Boats General Discussion >> RE: RC Surfer
Page: <<   < prev  160 161 [162] 163 164 165 166 167 168 169   next >   >>
Login
RE: RC Surfer - 2/28/2012 4:49 PM
RC HAWAIIAN STYLE
Score: 118
Last Login: 5/21/2013
Status: offline
cananzi
   is that your new ride  the board is working really good it never catchs the rails and the spray off your cut backs ,, sick .           maui john
_____________________________
BUILD IT YOUR SELF ,I DID
Hide Signatures
(in reply to Cananzi)
       Post #: 4026
RE: RC Surfer - 2/29/2012 11:16 PM
jocktime
Score: 100
Last Login: 5/4/2013
Status: offline
2 New Boards From Mauircsurfer.com
02/29/2012
Link: http://www.mauircsurfer.com/HD-Video.html
Long runtimes..........Jock
Innovation, Creation
Hide Signatures
(in reply to RC HAWAIIAN STYLE)
       Post #: 4027
RE: RC Surfer - 3/1/2012 3:07 AM
Saildoggie
Score: 100
Last Login: 3/27/2013
Status: offline
Whoa! Those boards look unreal!
The Dudes are awesome as well, the one with the tongue out, YEEA!
Nice work John, cannot wait to see those in the water!
Hide Signatures
(in reply to jocktime)
       Post #: 4028
RE: RC Surfer - 3/1/2012 6:47 AM
Cananzi
Score: 101
Last Login: 9/27/2012
Status: offline
maui
the boards look awesome! cant wait to see them in action. you guys are honestly the kings of customs. Well done
Goldcoast ****
http://goldcoastrcsurfers-com.webs.com/
Hide Signatures
(in reply to Saildoggie)
       Post #: 4029
RE: RC Surfer - 3/1/2012 6:48 AM
Cananzi
Score: 101
Status: offline
maui
Goldcoast ****
Hide Signatures
       Post #: 4030
RE: RC Surfer - 3/1/2012 4:07 PM
RC HAWAIIAN STYLE
Score: 118
Status: offline
cananzi
thanks   but i think you are the king of customs   ,yours work so good , i would love to see the bottom of yours.          maui john
Hide Signatures
       Post #: 4031
RE: RC Surfer - 3/1/2012 11:12 PM
Jimi Findrix
Score: 100
Last Login: 5/23/2013
Status: offline
Awesome surfer Cananzi!
Go to the beach, that is what we do! (Classic JT)
Hide Signatures
       Post #: 4032
RE: RC Surfer - 3/3/2012 7:49 AM
Hughengland
Score: 100
Status: offline
Hugh's 5th Custom build - 28" x 10" rounded pintail, EPS core, no stringer, 100% carbon.
Lots of Veeeee in bottom, no keel, 2 carbon deck lids (one for surfer dude & one for GoPros).
Hopefully this board will hold onto/into the biggest wave faces.
Just finished initial mounting of engine mount & prop drive shaft - epoxy drying overnight.
See pictures below
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Jimi Findrix)
       Post #: 4033
RE: RC Surfer - 3/5/2012 12:05 AM
RC HAWAIIAN STYLE
Score: 118
Status: offline
hugh
 your new ride is the sh*t      love the carbon , that s the same V i use    maui john
Hide Signatures
(in reply to Hughengland)
       Post #: 4034
RE: RC Surfer - 3/5/2012 10:45 AM
YPC
Score: 145
Status: offline
Hi
Looks like 'great minds think alike'
I introduced the 'V' on my first build and it definitely ran pretty smooth - even for its size and very light weight.
The hydraulic effect ( lift) is hugely reduced with the V bottom- so a lighter hull can travel through chop - with better stability.
My new build - 700mm long - 180mm wide- has an even deeper V- I incorporated the entire pod depth into the V. I found with the first build that the board has a tendency to climb onto the pod at speed, which intern makes the board unstable. I dont think it is as noticeable with the heavier boards, but I want to keep the board as light as possible for longer run time and cheaper running hardware cost.
The drive shaft is housed in a very slim skeg so there is very little drag in the water. The skeg that will hold the board in the turn even more effectively than a pod.
The V bottom will undoubtedly make for the boards handling the choppier water surface even better, as well as simply running with better stability and smoothness.
I have put quite a bit of rocker in the board as well, which should also help on the hollow face.
Totally loving this STUFF !!!!!
Regards
Dominic (YPC)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4035
RE: RC Surfer - 3/5/2012 4:37 PM
RC HAWAIIAN STYLE
Score: 118
Status: offline
dom
  new board is sweat ,   cant belive thats the sceond board you have ever  made   we are lucky to have  a pro builder on are team like you    keep up the good work     maui john
Hide Signatures
(in reply to YPC)
       Post #: 4036
RE: RC Surfer - 3/5/2012 5:10 PM
YPC
Score: 145
Status: offline
Hi Maui John
Thanks for the Thumbs Up !
Its really fun 'shaping' these boards - its like having a 'poetic licence'..........................................building 'RACING hulls' can be a bit to 'detailed' at times.
I am wanting to achieve so much with this board = Aim for the lampost and hit the pavement...............LOL
Since the last update I made a RETRO wooden skeg ( glassed)
I have also added the deck rim - this stops the water from penertrating under the deck between the seal.
I was hoping to transfer the electrics from the previous board and test soon - BUT - my ESC seems to be DEAD - I knocked a whole in the first board 'on the rocks' and got every thing wet. I thought these units were 'Water Proof ?????
I am going to POT the new ESC in a Potting Epoxy so that NO WATER can get to it...................................
Regards
Dominic (YPC)
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by YPC -- 3/5/2012 6:00 PM >
Hide Signatures
       Post #: 4037
RE: RC Surfer - 3/6/2012 3:03 AM
Justin-san
Score: 100
Last Login: 12/24/2012
Status: offline
The boards look AWESOME guys!!! Very professional.
I pulled some BIG hunks of EPS out of the trash at work and will carve them down.......when I have time. I've been playing with planes, quad copters, trucks and crawlers again.
I too have soaked a "water proof" ESC and killed it. I now squirt silicon seal into the ends of the ESC and it seams to work fine keeping the water out.
Justin
Hide Signatures
(in reply to YPC)
       Post #: 4038
RE: RC Surfer - 3/6/2012 9:09 AM
Hughengland
Score: 100
Status: offline
Monday 5th, Maui North Shore, Paia Bay
6 bricks used today on 3 different boards.
Conditions were perfect with 4ft-8ft perfect silky smooth wave faces, no wind and very few surfers(work & school)
Wish I had someone to rc surf with in these perfect conditions.
All charged up and ready for another big session tomorrow - forecast on TV news tonight is 15ft waves with dangerous conditions.
Hide Signatures
(in reply to Justin-san)
       Post #: 4039
RE: RC Surfer - 3/6/2012 9:57 AM
YPC
Score: 145
Status: offline
Hey Hugh ! - you lucky chap !
Could it have got any more perfect than that ? ..........................next time give me a call................... love to join you................. LOL
What I am really enjoying about RC Surfing is that I dont have to wait for the ' Once a Month' race day to get my kicks.
I can head out to the beach (3 minutes from home) and have a blast 'most days' - most any time.
The design aspect of these boards is limitless and the potential for so many various moves/tricks on the wave face are endless.................certainly can keep one captivated.
I have designed this board with the prop and skeg further in from the tail - intending to reduce the lift in the tail, especially in the turns. ( less leverage)
With the skeg more forward - when the turn is actuated, more of the inner rail should be pulled into the water, making for a longer rail to carve the turn.
The 'rocker' in the tail should allow for the nose to lift in the turn and give a degree of grace in the hollow sections.
Definitely a sport that has captured my 'sweet spot'
Regards
Dominic (YPC)
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4040
RE: RC Surfer - 3/6/2012 9:14 PM
YPC
Score: 145
Status: offline
For those who grew up reading 'Comic Books' - like I did - pictures sure tell a better story ...................................
Some further progress to the build.
Dual WATER intake - one for motor and one for ESC - most ESC's have a more restrictive flow than the motor water jackets. dual lines keep both components much cooler - especially at lower speeds - allows for more run time.
Steering servo mounted of the deck - to access the mounting screws easier.
Rudder/skeg pivot shaft and control control arm in a separate housing to prevent any water leakage into the main housing. The two housings will be covered by a single deck cover - but have separate water seals.
With motor and battery in place - CG = 45% - measured from aft. - ideal
Plenty of room for battery choices - can play around with various battery pacs to achieve altering CG for different conditions and riding attitude.
Side Note
Last picture - hand made Stainless Steel 'ENIGMA CAMBER outboard leg for a F1 Gas boat - of to the USA in the morning - this latest design of mine actually cambers (tilts) when it turns - so it shifts the power heads CG and the cambered skeg 'rolls' the tunnel hull into the turn - faster /tighter turns - Big advantage.
and so on................................................loving it !............................. already thinking of the next one.....LOL
Regards
Dominic (YPC)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to YPC)
       Post #: 4041
RE: RC Surfer - 3/7/2012 3:45 AM
Hughengland
Score: 100
Status: offline
Tuesday North Shore, with John on camera - thanks John
Hugh's Sheila ripping up inside small sections of Paia Bay
Batteries are a charging - looks like it will be same tomorrow (after golf)
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to YPC)
       Post #: 4042
RE: RC Surfer - 3/7/2012 4:37 AM
surfcurls
Score: 100
Status: offline
Nice Rides Hugh !
Maui J Has The Eye For Sure ...
Surfcurls
Hide Signatures
       Post #: 4043
RE: RC Surfer - 3/7/2012 9:57 AM
itsfishi
Score: 105
Status: offline
some more bad self filmed bad surf footage lol. from today. managed to do 4 packs today and filmed about the worst of it. did get one good session at cowries which was nice, but pretty much blown out at the moment
Hide Signatures
(in reply to surfcurls)
       Post #: 4044
RE: RC Surfer - 3/7/2012 11:38 AM
YPC
Score: 145
Status: offline
Hi Fish
Your set up is looking very quick and turns on a dime. Great acceleration !
How have you managed to film so steady with the action in the center of the frame ?
Regards
Dominic (YPC)
Hide Signatures
(in reply to itsfishi)
       Post #: 4045
RE: RC Surfer - 3/7/2012 11:49 AM
itsfishi
Score: 105
Status: offline
hi Dom i just held the phone in my right hand and drove with left, thumb steering. lol.
yours and hughs new boards look sick cant wait to see how they go, could be new revolutionary design.
looking at your board have you thought about going with a water jacket on your motor instead of coil, jacket will provide much better cooling. HK has em pretty cheap when in stock.
another trick mostly for leaky nqd's is to grease up your servo this will waterproof it pretty good. just smear it all over the whole thing.
speaking of waterproofing! ESC'S alot say they are waterproof and they are not, the marine 120 i got says it and its not, i have filled both ends with marine sikaflex really good around the wires all over and it has done the trick.
swell rising tomorrow but will be windy again
later
Hide Signatures
(in reply to YPC)
       Post #: 4046
RE: RC Surfer - 3/7/2012 12:14 PM
YPC
Score: 145
Status: offline
Hi Fish - not bad for 'thumb piloting'................................got to be awesome with 'two hands........
Really enjoying the building !- worst case scenario it will be a really cool FE for one of my sons...............................
I use clear nail varnish on the seams of the servo and a small'o' ring around the horn with a tad of rubber grease. We actually run the top of our servo's exposed out of the radio box with the F1's
As for the ESC - Im going to try and 'POT IT' - mold it completely in a 'low heat curing' epoxy.
The coil on the motor was a Sunday rush job ( after I blew the small motor) I will order a jacket from HK
I managed 25 minute run time with a 3600 mAh set up using the coil - so a jacket should add more value.
Hope tomorrow brings you some 5 ft hollow - long rides !
Regards
Dominic (YPC)
Click for fullsize
Hide Signatures
       Post #: 4047
RE: RC Surfer - 3/7/2012 4:15 PM
RC HAWAIIAN STYLE
Score: 118
Status: offline
fish
 you shot tthat with a cell phone while you are driving your surfer ,, dammm you got skills         maui john
Hide Signatures
       Post #: 4048
RE: RC Surfer - 3/7/2012 9:48 PM
kitekook
Score: 100
Last Login: 5/18/2013
Status: offline
Lolocarrera
I see you are online....
got any new models....I just love your Surfers...
kite
Itsfishi
Looks like the same surf we have be having for a week now, been waiting for something better than a 'POOR' rating on Surfline.com...gonna have to go out tomorrow...got a new gal and ride.
< Message edited by kitekook -- 3/8/2012 6:41 AM >
Hide Signatures
       Post #: 4049
RE: RC Surfer - 3/7/2012 10:30 PM
itsfishi
Score: 105
Status: offline
Swell is up probly about 5-6 foot but it's real windy and raining which sucks and can't see a break although I'm sitting in the car at the beach hoping it stops for a bit lol. Hope the weather is better where you are
Later
Hide Signatures
(in reply to kitekook)
       Post #: 4050
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
