RE: RC Surfer    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Boats General Discussion >> RE: RC Surfer Page: <<   < prev  214 215 [216] 217 218 219 220 221 222 223   next >   >>
Login
RE: RC Surfer - 9/20/2012 12:54 PM
stalyoni
Score: 101
Last Login: 11/26/2012
Status: offline
thanks guys so much for all your help.
I just chucked the motor in the freezer and ill see if it will slip off in the morning. I wont be using this motor again so it doesnt matter.
I just need my dads brains as he is very cluey about these sorts of things.
thanks
Brendon.
Hide Signatures
(in reply to trippergreenfeet)
       Post #: 5376
RE: RC Surfer - 9/20/2012 1:11 PM
YPC
Score: 150
Last Login: 6/19/2013
Status: offline
Stayloni...........this forum has 'all the help' you will need....you just need to invest the time in reading all of it. Its well worth it.
The Freezer 'wont' damage the motor...
Bro rcSurfer
share the STOKE
Hide Signatures
(in reply to stalyoni)
       Post #: 5377
RE: RC Surfer - 9/20/2012 5:37 PM
willhappy
Score: 100
Last Login: 5/5/2013
Status: offline
hi stalyoni
thanks mate for that, looking into that.
ok next question whats the best motor and battery and speed control for the lisa surfer.
will
Hide Signatures
(in reply to YPC)
       Post #: 5378
RE: RC Surfer - 9/20/2012 10:02 PM
stalyoni
Score: 101
Status: offline
YPC the freezer trick didnt work mate so I will have to get dad to get it off somehow.
Will tripper and I will be running the SL2848 3900kv motor for hobbyking. As for a battery I havent gotten that far as I havent mounted the motor yet.
hope this helps a little.
Hide Signatures
(in reply to willhappy)
       Post #: 5379
RE: RC Surfer - 9/21/2012 12:19 AM
stalyoni
Score: 101
Status: offline
success!!! I got the hex brass fitting off. I used some pliers, sidecutters and a hammer and got it off. Now the next step is securing the motor. I think I will leave that part up to dad. I really cant see an easy way to secure the motor.
Does anyone have an ideas given the picture ive put up?
Hey tripper is there any chance you can put up a close up pic of your mounting plate?
thanks
Brendon.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 5380
RE: RC Surfer - 9/21/2012 12:57 AM
surfcurls
Score: 100
Last Login: 6/14/2013
Status: offline
You will have to make a custom mount if you use that 380 can size motor.
The stock mount from that board is for a 540 size motor, but that will lead to a 5mm motor shaft
and a different prop shaft and coupling to fit it.
KITE: Kelly Just Won Trestles !!!! It was awesome...
_____________________________
Surfcurls
Hide Signatures
       Post #: 5381
RE: RC Surfer - 9/21/2012 2:31 AM
surfcurls
Score: 100
Status: offline
Looking at the Huge International interest in Rc Surfing, and the global builders the hobby sport now has
I am contacting the ASP with the help of my Pro Surfer Contacts to hold exhibitions during the lulls that would showcase the Rc surfer.
We have France, Brazil, South Africa, Australia, Hawaii, The US, and more.
As A Group we could actually pull this off.
I will help start it and will be working on this. contact me if interested.
Thoughts so far:
Australia - Wombarra / Andy Team
Brazil - Jeff Team & More
France Team - Brice & Blog Team
South Africa - YPC Team
Hawaii - Maui John Team
US Mainland - Surfcurls / Kite Team
Surfcurls
Hide Signatures
(in reply to surfcurls)
       Post #: 5382
RE: RC Surfer - 9/21/2012 4:09 AM
surfcurls
Score: 100
Status: offline
Here Is The ASP Tour Schedule, I have already Contacted ASP and Some other VIP's
Here is The ASP Tour
Feb 25 - Mar 7, 2012
Gold Coast,Qld, Australia
Apr 3 - 14, 2012
Bells Beach,Victoria, Australia
May 9 - 20, 2012
Rio de Janeiro, Brazil
Billabong Rio Pro
Jun 3 - 15, 2012
Tavarua/Namotu, Fiji
Teahupoo,Taiarapu, French Polynesia
Trestles,California, United States of America
Sep 28 - Oct 8, 2012
South West Coast, France
Oct 10 - 21, 2012
Peniche, Portugal
Nov 1 - 11, 2012
Santa Cruz,California, United States of America
Dec 8 - 20, 2012
Banzai Pipeline,Oahu, Hawaii
Surfcurls
Hide Signatures
       Post #: 5383
RE: RC Surfer - 9/21/2012 6:13 AM
trippergreenfeet
Score: 100
Status: offline
Stalyoni
I can't supply a photo but what I did was used a piece of 8mm ali angle, drilled two bolt patterns, one for the motor and the other for the stock mount (counter sunk).  I then used countersunk screws for mounting the ali to the stock mount (1st step) and standard button heads to mount the motor second step. Then just secure the motor and mount to the stock holes in the board. It does pay to fill the holes in the board with some epoxy and redrill once cured, there's not much bite in the plastic, there is the issue of stripping the plastic with overuse as the motor has to be removed to grease the shaft each time.
Hide Signatures
       Post #: 5384
RE: RC Surfer - 9/21/2012 7:17 AM
Hughengland
Score: 100
Status: offline
Aloha Surfcurls,
Pipeline & Off the Wall with only rc sufers in the lineup - sign me up!
Hugh
Hide Signatures
       Post #: 5385
RE: RC Surfer - 9/21/2012 12:57 PM
stalyoni
Score: 101
Status: offline
thanks tripper but dad and I spent hours today and got the motor mounted. I wired up the ubec and esc.
All I need to do now is epoxy it all up and make the reverse rocker tail mod.
I have a hxt900 9gram servo cable tied in for the steering at the moment. Do you think this servo will be enough for steering?
Ill put up some pics of what we did after I epoxy it all up.
Its really taking shape now and thanks so much for all the help along the way guys.
Hide Signatures
(in reply to Hughengland)
       Post #: 5386
RE: RC Surfer - 9/21/2012 6:14 PM
kitekook
Score: 100
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: surfcurls
This all seems a bit premature to me.
For sure they ALL wanted a piece of Nikki last week while they were setting up, I could feel it, I just handed out cards and smiled alot. Why wouldn't they, Nikki is beautiful, one of a kind, and best of all, she tears it up!...but she is not for sale.
ASP and Hurley would love to have a side show so unique...especially if its free....there is the rub...
With no horse in this race..the question that comes to mind is....??????WHY???????
Promote our sport?
= Crowded breaks
or signs that say No Rc Surfing Allowed....because some hotshot bought a Surfer and got stupid.
Fame?
Yea Right!
If ASP or Hurley wanted to sponsor Nikki and the rest of the Divas next year(that would give us time to get the Team ready)...that would be a different story...travel, lodging, and daily stipends would go a long way in making the effort worth while, one could put on quite a show...but they want FREE...don't they.
I can understand why this would be a good deal for Surfcurls, Womberra, or any other manufacturer of 'lets pump out a thousand and see how it goes' production models...but BEWARE, that is not what impressed them in the first place. They want a Surfer that has some size, shows off its power with speed and dominance over the whitewash, shreds up the wave faces with ease, jumps high, and seems near indestructible!
Maybe that will describe the new production models on the horizon...available any time soon?
In fact with the exception of Maui Rc Surfer there are not ANY for sale. How many Surfers can a guy make and still enjoy the process?
Which leads me back to my original point...this all seems a bit premature to me.
Hide Signatures
       Post #: 5387
RE: RC Surfer - 9/21/2012 6:49 PM
Hughengland
Score: 100
Status: offline
Kite,
Well said mate, here in Maui we are very protective NOT to promote the sport, as we do not want even a few irresponsible **** who could ruin it for others.
We figure if someone wants to make and maintain his/her own rc surfer - then chances are they would be responsible and welcome.
Right now there are 5 of us that rc surf on Maui
I agree with what you said in your post BUT given the chance to rc surf Pipeline or Back Door without real surfers in the water - I would do it for free for ASP
Hide Signatures
(in reply to kitekook)
       Post #: 5388
RE: RC Surfer - 9/21/2012 10:15 PM
surfcurls
Score: 100
Status: offline
The idea of having **** as part of real Pro surf contests is Not New.
Ed & BB participated in some events 10 years ago.
Four Years ago, I was approached by Surfline, and I declined.
I don't think it's pre mature, I think it's long over due.
Every time an Rc Surfer Gets put in the water, It's promoting the sport,
Unless you are surfing in total seclusion.
It boils down to educating the user on the safety issues...
Surfcurls
Hide Signatures
       Post #: 5389
RE: RC Surfer - 9/21/2012 10:30 PM
surfcurls
Score: 100
Status: offline
Don't worry Guys, The Malibu Beach Cops were not shutting down the ****
They Were Stoked to watch them.
Click for fullsize
Surfcurls
Hide Signatures
       Post #: 5390
RE: RC Surfer - 9/21/2012 11:05 PM
RC HAWAIIAN STYLE
Score: 118
Last Login: 6/16/2013
Status: offline
kite
    YOU  HIT THE  NAIL ON THE HEAD,, THREE CHERRS FOR KITE  PRO
                                MJ
BUILD IT YOUR SELF ,I DID
Hide Signatures
       Post #: 5391
RE: RC Surfer - 9/21/2012 11:11 PM
YPC
Score: 150
Status: offline
I strongly agree with 'best ensuring' the surfing of rcSurfers responsibly.....it would be tragic if ones local beach spot was permanently closed to rcSurfing. These little guys could do some serious damage in the wrong hands.....
As for the ASP......I reckon that event is best left for the Pro's......as Kite questions......what would we hope to gain ?
I managed another fun session this afternoon- in between rain showers and sun shine moments - 'small' 1-2 ft face.....I need as much time in the water....practice makes perfect.
I'm so enjoying this board. Its seems to handle most all conditions well. Has run faultlessly so far...
I dumped the single fin after a few waves today......really just prefer the Bi-Fin 'all in all'.....to me it seems to do the job 'just' that much better.
Bro rcSurfer.......
Share the STOKE !
Hide Signatures
       Post #: 5392
RE: RC Surfer - 9/22/2012 12:27 AM
surfcurls
Score: 100
Status: offline
Due To The responses Thus Far on The ASP, I will let them know There is not Sufficient Global support
at this time to pull it off . Heck it was just a thought.
The Association Addressing Safety, Seems to be stalled as swell.
Hurley buys the Budweiser & Bratwurst at Next Bro Down....
Surfcurls
Hide Signatures
(in reply to YPC)
       Post #: 5393
RE: RC Surfer - 9/22/2012 2:02 AM
Hughengland
Score: 100
Status: offline
Bummer I was looking fwd to Pipeline by myself.......!
Hide Signatures
       Post #: 5394
RE: RC Surfer - 9/22/2012 2:47 AM
kitekook
Score: 100
Status: offline
Bro sure jumps high!
Hide Signatures
       Post #: 5395
RE: RC Surfer - 9/22/2012 4:33 AM
kitekook
Score: 100
Status: offline
quote:
ORIGINAL: Hughengland
MJ,Hugh,Jock,Karl....whose #5 ?
Hide Signatures
       Post #: 5396
RE: RC Surfer - 9/22/2012 4:48 AM
surfcurls
Score: 100
Status: offline
Hurley Trestles 2013 Could be a blast !!!
< Message edited by surfcurls -- 9/23/2012 4:40 AM >
Surfcurls
Hide Signatures
       Post #: 5397
RE: RC Surfer - 9/22/2012 6:59 AM
YPC
Score: 150
Status: offline
Howzit Guys !
Kite.......yeah ! Bro does seem to reach for the clouds easy enough.....also mostly makes for good landings.
[Doc...rcSurfing has had almost '30 years' to go big - yet it is still only really been enjoyed by a 'handful' globally.....I dont 'sea' the trend changing any time 'sooooooooon'
The cat may be out of the bag......but......?......it far from having litters....LOL
Hugh......picture of Bro's back hand Pipeline rendition......its the closest hell ever get........LOL
Hope everyone pulls into a few great waves this weekend !
Bro rcSurfer. ...
Share the STOKE !
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5398
RE: RC Surfer - 9/22/2012 1:45 PM
bearcave
Score: 100
Last Login: 6/18/2013
Status: offline
My biggest fear is that someone buys a going real rc surfer then takes out someone's eye or cuts em up with 2kg plus of plastic missile.... the powers that be will not like that and laws will be introduced ruining everything for everyone...
It happened during my fun with HPI nitro savage 4wd's.... my local council used to dump big mounds of dirt around the playing feilds for future topsoiling, which with shovels and home made ramps we realy had some fun... the kids practicing their footy loved it too but not the parents... OMG 5kg of noisy oil burning machine hurting my child.... council please stop them..... Long story short no more dirt is placed anywhere near a sporting field.
Then again demo sessions at certain times mutually benificial to organisers and surfers could/should be promoted why not.... espec if you get to have pipe for yourself lol that would be priceless!.
I know some of you would like to make a buck out of this persuit and getting in first with good product helps as with any bussiness and i'm not being a party pooper BUT while many are not into RC machines and handy with tools, mega waterproofing, boats/surfing, weights and balances, swimming, battery care and chargeing glues and resins glass and fibre etc etc etc not to mention the "maintenence and time" needed to be consistent.... i hope we can have a few more years surfin while the big cat is still within the bag...
YPC... what kind of video camera do you use in your vids.. It seems to have enough zoom your vids are cool.
Thinking of doing a helmet cam not Transmitter cam with a proper vid cam not a std digital cam...any tips on zoom rates hd antishake or anything worthy of mention... they are kinda expensive with so many variables its mindboggleing but you do have a methodical technical brain.... BTW until tripper visits you and shares his surfing tips try a banana... meaning think of nothing technical while surfing... just surf... while within your head is just well, just a dumb old banana!
Any tips from yourself or anyone most welcome.  thanks bearcave.
Hide Signatures
(in reply to YPC)
       Post #: 5399
RE: RC Surfer - 9/22/2012 6:39 PM
Hughengland
Score: 100
Status: offline
John - I see you are online - is there any surf near your house?
I see waves breaking on Lahaina cam...
Await your reply or call me - as North Shore still flat
Hide Signatures
(in reply to bearcave)
       Post #: 5400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.188RCU1
