RE: RC Surfer (Full Version)
All Forums >> [RC Boats] >> RC Boats General Discussion
Message
InDaTube -> RE: RC Surfer (1/31/2013 11:49 PM)
Kite......
What motor are you using with the 5S setup?
You are so happy with the performance..... Is it the motor or 5S setup.... or both.
MJ let me surf his new board several weeks ago and it was so quick and powerful.
My next MauiRCsurfer Leapord powered with 5S.
InDaTube
YPC -> RE: RC Surfer (2/1/2013 1:35 AM)
Howzit Curls...
I can definitely see a distinct difference in the ride attitude between various boards. Some boards 'just' seem to turn left and right with the Surfer barely budging into a lean ,,,,2D......very Boat like........almost static.
Other board's have a flowing 'YAW' effect - I like to call it 3D - where as, in the turn......the tail drops and the surfer leans into it.........
The pictures below demonstrates the kind of' lean' effect I am after, although it will obviously not be as steep in the water. The CG will also be further aft when all the running gear and battery is fitted. The boards outline rail shape, with the narrowing toward the tail, lends itself to the tail dropping in, as the pod shape and size should lift the center line up front....rolling the board onto the inside rail...resulting in a 'YAW' 3D turn................
Kite.....both of those stories were 'NASTY'.......whats up with the surfers...Simply Bullies !..........Man ! I would not be happy hitting a reef/rocks with a board.......damaging a great prop really hurts.......I've had that with racing.......
It sure sounds like you have found your 'SWEET BOARD' in the 5s set up !...............I don't think it will be long before you will have that 'second' 5s board..........maybe a cute 'lady friend' for Horse to surf with..........
Bro rcSurfer. ...
Share the STOKE !
kitekook -> RE: RC Surfer (2/1/2013 2:46 AM)
IndaTube
I have been using the same motor for a while now.
I starting using the Turnigy XK 3665-B-2300 on Maui Johns' suggestion.
It was/is a great motor....it's only downfall...they don't make it any longer! and it will not take the voltage the 5S puts out.
I read on one of these forums that the Turnigy was the Leopard knockoff...
hummm, I looked into it and sure enough Leopard made the same motor 3665-B-2300
This motor is capable of handling the voltage of the 5S! up to 26v if I remember right.
They are extremely hard to find.
You see, Leopard stopped making them!
I managed to get one used and two new ones over the past six months or so.
I thought I had recently found a goldmine....his website said he had 7!
I ordered one to make sure it was the right motor...he emailed me back and told me he only had the one.
Its hard to say what has made the difference... the 5s batteries? the 36 x 55mm prop? or the shaping of board #24 ?
Every thing else is the same...ESC, servo, receiver, and rudder/linkage.
But the difference is night and day!
Dom
My last couple builds required no additional weight to self-right...and they have been the funnest to Surf.
The key, and you touched on this, is the lighter Surfer figure.
I am now squeegeeing off the resin from the cloth before I apply it to the foam...that excess resin was weighing the Figures down!
Its a little harder/slower, and sometimes I have to add a little more resin to make things stick to complex curves...but overall it is much lighter.
Maui John once told me that resin without glass was just dead weight....took about six months for that one to sink in.[:D]
As soon as I got the weight down to around 10 oz I stopped needing the extra weight...even while reducing my total weight, going back to using only one layer of 6oz top/bottom, and a two inch wide strip along the rails.
I would like to bring back the Divas....just got to figure how to do the hair... I cut off Melika's head and weighed it....it was over 3 oz! the light foam heads weigh around 3/4oz.
She in for major surgery...I have an idea...we'll see.
The only difference between the 4s and 5s boards is the depth of the battery compartment....if I can come up with a way to make them bigger...I have several spare boards, thinking on that one...
I say 'the only difference'....but really, none of my other boards compare to what I was able to shape into #24...the rocker, the extended flatness out the back, the xtra 'Vee', more volume here and there, and on top of all that, all the 'mana' that just poured threw me into this one...probably why it feels like a Magic Board.
Looking towards #25..but first I have to make the Surfer...then his board.
surfcurls -> RE: RC Surfer (2/1/2013 4:18 AM)
Hey Dom
Your boards seem to be riding 3D, Even in slo Mo. Just Perfect.
Not sure why you are looking to improve it ?
I think the bigger boards have the 2D issue, Not to dis, just a thought Looking at the footage available.
My Kopy tybrid boards have soft rails at the nose and tail, and hard rails in the center of the hull.
The Board leans into / out of turns and the nose has a ton of rocker. No Neg Rocker at Tail.
WindanSea
It's a notorious local spot with years of history.
The Locals Can be quite aggressive.
Take A Look
http://www.nytimes.com/2008/05/12/us/12surfer.html?pagewanted=print&_r=0
InDaTube -> RE: RC Surfer (2/1/2013 4:38 AM)
Hi Guys,
On the topic of leaning into turns, like on a cutback or bottom turn I'm finding that how you make the turn makes a lot of difference.
If I turn too sharp and jerky, sure the board responds quickly, but the turn is much flatter and doesn't look very realistic.
If I smoothly carve my cutbacks or turns hold the edge thru most of the turn...... bingo, a pretty realistic leaning and carving turn.
I'm sure board design has a lot to do with it as well. My board has a flat tail with very sharp rail edges for instance.
When I'm surfing and make a jerky turn or cutback, the problem is me.
Here is two photos..... zoom in and see the details of the turn, hole the turn tracks, the edge holding and carving. Even InDaTube leaning while making the turn.
Thanks.....
InDaTube
CURLS........
Thanks for the info.
YPC -> RE: RC Surfer (2/1/2013 5:53 AM)
Hi Kite !
I recall your hatch lids being Standard for all your previous boards - what about making a new hatch lid that will be able to take up the added thickness of the battery. simply make a square plug the size of the battery square area and added depth, then mold over that. Your surfers back leg will be a tad shorter when bonded onto the hatch cover - You wont see the battery hump from a distance and you will get to run your previous boards 5s.
Curls !......perhaps........but I would like it to be 'more apparent'......plus !I love the continuing development.
Indatube......you are so right......I did forget to mention......the board 'cant do it all'.......the surfer has to play his/her part....thats the great thing about rc......it also has a technical challenge that keeps one coming back for more 'practice'.........just like the real thing.....I sure as hell wont be doing any of Kelly's moves even if I had his board under my feet...........LOL
Really great pics........the second one is STUNNING !
If I don't chat later in the Day ! Have a great weekend all....... US team - don't put to much money on the upcoming Superbowl game ! and help get rid of all those guns............
Bro rcSurfer. ...
Share the STOKE !
bearcave -> RE: RC Surfer (2/1/2013 8:35 AM)
surfing was great when i was young... the hard ass local dudes gave me greif werever but cause i had friends we could surf "their" breaks cause when the punchin was on there was backup.... faark only lived 5min from the local breaks but were 'not local' and needed to be minced.... understand the mentality but always hated that about surfin still do.. best thing to do back then wherever you were was was to take out the alpha legend and the rest would be our mince or run away..... havin a drink at the local later was pretty much the same.
Anyway at the local break there was this redheaded scum A hole that would throw big rocks on your boards from "his' and his mates walkin track above when we wouldn't let them use our boards for a quick slash.
Long story short bigger and badder dudes eventually took him and his mates out and they were gone.... BUT this redheaded freak could ride a "borrowed" kneeboard standing up better than the kneeboarder who rode it.... and better than the stand up guys on their own boards....
Therefore thinkin while the ultimate board will make a difference.... InDaTube's recent comments make much sense.... just sayin
YPC -> RE: RC Surfer (2/1/2013 8:55 AM)
Hey Bearcave.......cant say that I have ever enjoyed the 'attitude' of locals......its not really tolerated over here..simply ..the ocean belongs to 'everyone' .......big or small....grom or pro......as long as the rules are followed, all should be entitled to have fun.......all the time.
We have a guy who boogie boards on a plastic dustbin lid......rips the wave face apart........LOL
Before I return my previous board to its rightful owner who has been very generous to allow me to use the elecs to set my new board up while I wait for that slow boat out of China, I have taken a few comparison pictures.
Got the Gloss Coat polished.
Dam I cant wait to get this board wet !
Bro rcSurfer. ...
Share the STOKE !
bearcave -> RE: RC Surfer (2/1/2013 12:43 PM)
hey YPC thanks for the thoughts on my question regarding the hull screws... have also been caught out before with the machining oil that is left on most things made of stainless steel... all good
maybe i'm diggin a hole for myself for all ausies watchin this forum but  would like to add that when rabbit was punched out by the hawaiin black shorts (as we heard it here in oz) i was kinda happy..... yeh big call he was a founder of the aussie surge, surfed good took anything on loved his way of life actually like the guy too but imo didn't like the way he done it back then.
Also didn't like that when a punch on was on in the line up a legrope could be looped around your neck while into it underwater, just before the freak set, yeh i'm pissed off with local aggro **** but faark just how it was....... maybe still is....
Respect for everyone wether loosers or winners from loosers or winners would be nice....we are only here once and it may be an unatainable goal but **** just sayin
bearcave -> RE: RC Surfer (2/2/2013 11:20 AM)
quote:
ORIGINAL: kitekook
Today we headed out the door...my van started acting up![:@]
Ran over to our neighborhood mechanic, Angel, he got me in and out before I finished my Starbucks Coffee...Turned out I had a couple vacuum hoses slip off?????
and, my battery was shot!
I found it funny...I do not flinch at buying expensive Lipo's...i had to remind myself this as I purchased a new battery for my van trying to avoid the impulse to go cheap...
Van is fine
Hi guys just reread my latest rants.... no point editing them now.... sorry for getting off the track of the forum.
Like surfcurls has mentioned rcsurfing atm is a cat out of its bag..... those into it no doubt see the fast movement last few years.
As far as i know there are no councils beach patrols or regulators whatever restricting us by law to where we can surf.... as long as we stay away from patrolled swimming area's and treat ourselves as 'surfcraft' and respect all other surfcraft we are cool...?
I am very worried that localism,  jealousy,  a fast moving weapon in the wrong hands,  etc etc etc..  may jeopardise our so far imo free rcsurfing trip.
It will only take one bad accident and/or punchup to get the regulaters involved and possibly screwing our ride forever.
I would realy like us all to keep this in mind.... imo if rcsurfing becomes like real surfing we are doomed.....
Kite..... as a mechanic i can gaurantee that if your van worked fine when you parked it and didn't backfire within the inlet manifold when you started it next day... vacuum hoses do not just fall off.....
Hey maybe just a coincidence but my gut feelin is if i was you would just be checkin my back every now and then.....
ok enough gloom and doom.... back to the cave for some hibernation... (thank god i hear you all say) ... already dreaming of the awsome vision coming our way soon from Bro Down #3
RC HAWAIIAN STYLE -> RE: RC Surfer (2/2/2013 4:15 PM)
.Bearcave
      i hear what your saying,,    for bro down three ,, we have to find a spot with no surfers  out ,, last time we were invading lots of  young surfers,, that's no fun ,,     maybe we can go to DMJ s   on the military base,, bad billy can get us in,    just a thought
                                maui john
YPC -> RE: RC Surfer (2/2/2013 9:47 PM)
Hey ! ......my ship arrived from China !
Saw the "Chasing Mavericks" movie this evening............absolutely awesome........ don't know about rcSurfing it ..............LOL
Finally setting up the radio box....as much as I have not had water issues.........never say never when it comes to water !!!!!...I seal the steering servo in various ways......this time with duct tape over the joints and a small 'O' ring around the servo horn with some red rubber grease for lubrication.....works well.
I seal the ESC and RX entirely with "Til Tac' .......I think you guys call it poster putty.( for sticking posters and the like onto a wall)
Great to use a servo test unit when setting up the steering...... don't have to be bothered with the radio at the time. you can set the servo at its 0 point - travel it through its range..
My housings are all the same size..so I know where and how everything will fit in...compact !
Ran a battery through the system on the flat water in my back yard.......it looks very promising.......nose is running higher...tail deeper....leans very nicely....slightly more to the right than left when on the power ( prop torque) .......turns and leans nicely at speed, when dropping the power . No centrifugal fall over in tight turns. Self Righting no problem.
Bro....... officially ready to surf.......weighing in at 2025 g's (4lbs) ...........no lead added.
Hope the wind is not to strong in the morning......
THATS HOW WE EAT AN ELEPHANT..............ONE BITE AT A TIME...........
Bro rcSurfer. ...
Share the STOKE !
RC Resinator -> RE: RC Surfer (2/2/2013 10:58 PM)
 John,
     Are you going to be in the water with the GoPro on a stick for the Bro-Down 3?
All,
     Check out my latest RC surfer photos:  This is what you get when a GoPro meets a Mac...
     This board is close to 40"l and 12"w with a completely flat rocker out the back.  I've found that a hollow wave allows for better carving...I
 think I'm only going bigger, wider, heavier.
Aloha,
RC Resinator
RC Resinator -> RE: RC Surfer (2/3/2013 3:29 AM)
...A mispost earlier.  THIS is the correct image view of the surfer.
InDaTube -> RE: RC Surfer (2/3/2013 4:11 AM)
Post some photos of your board........ sounds very interesting.
Where were these cool photos taken?
By the way, what fastening system are you using? Some kind of wingnut?
InDaTube
surfkiwi -> RE: RC Surfer (2/3/2013 8:38 AM)
Hi all,
After a good 20 runs over a couple of weeks with my new stock NQD board and no leaks, it is time to upgrade the internals. The stock board has been good fun and I have definitely improved my skills, but I am now at the limit of what the stock board can do and it is getting frustrating :)
I have read a lot on the forum but I don't really understand it all. Can I get some help with electrics to get. I plan to order it all from HobbyKing and get it shipped to NZ. So if anyone can provide links to Hobby King for different bits, that would be appreciated.
Transmitter/Receiver:
Standard Hobby King 2.4Ghz
Motor:
I understand I should be looking for a 540 size water cooled motor with a 5mm shaft? What sort of kv should I be looking for?
Here is one I have found. Is this any good? Are there any cheaper options that would still be good?
ESC with BEC:
Are the birdie brand ESCs any good?
Or should I stick with a better one?
Battery:
Not sure what to get here. Some help appreciated. I would like one with the highest mah, but they all seem to be quite big and probably wouldn't fit into the battery compartment of an NQD. What would others recommend.
Also unsure whether to get a 2s or 3s? I guess this depends on the kv of the motor? What is the ideal RPM for an NQD board?
I have a LiPo balance charger that came with an Esky Helicopter I have. Is this OK to charge the battery, or should I be getting a better charger?
Fitting the motor:
Do I need to replace the shaft or get any connectors to fit a new motor?
Steering Servo - can someone recommend one?
Cheers,
Mark
YPC -> RE: RC Surfer (2/3/2013 9:13 AM)
Howzit Surfkiwi............
I'm a custom builder.......but will try and help.
One would have thought by now that 'their would be some kind of compiled list'.......personally " from experience......stay away from BIRDIE......I burnt a board out from the ESC catching fire......
JIMI.FINDRIX...... uses a leopard brand of motor with Kv around 3600 and a 2s battery.........It seems most go for a flex shaft drive.......
RC Resinator............ART in action................
Hit the beach this morning - strong onshore surf, but had to try it !.....................another day then !
COUPLING REPORT...............NOT GOOD...........lasted all of a few minutes in the surf.......clearly designed for lower load and RPM.......no problem, back to what has been working best.
Bro rcSurfer. ...
Share the STOKE !
bearcave -> RE: RC Surfer (2/3/2013 11:40 AM)
yawn...... sorry guys bear alarm went off had to have a look..... **** YPC can't beleive the metal dogs broke off too!
surfkiwi.... think 30% overrated for all things electrical.... 3s turnigy 3600 batt  was biggest i could get to fit stock nqd.....  2400kv motor with 3s may be same as 3600kv 2s havent done the math but have noticed bigger mah batts 2s are more suited to fit stock hull.... shaft size of motor has to match coupling you use to suit prop shaft....
yawn.... oops...... forgot i was hibernating..... zzzz
RC HAWAIIAN STYLE -> RE: RC Surfer (2/3/2013 4:36 PM)
RC Resinator
                                   i think i have been sniffing to much resin ,,, all i see is colors ,,,    pretty colors
        maui john             lol
YPC -> RE: RC Surfer (2/3/2013 6:33 PM)
Hi Guys................
Bearcave ! on close inspection.......the coupling unit was cast not machined.....simply to weak.
I recall - Jiimi runs 5000 (plus) mah 2s packs....I'm sure his boards are stock housings.
Sorted the coupling issue out, back to my standard aluminium coupler - went back for a quick single pack session this evening. still very onshore....but enough face to have some fun.
Board surfed 'very nicely'.......hope to have some good sessions this week
Bro rcSurfer. ...
Share the STOKE !
surfcurls -> RE: RC Surfer (2/4/2013 4:12 AM)
I'm Looking into different positions of the figure footing.
Testing to sea if there is a difference in performance by moving the figure more towards the nose
and also adding a bit of weight to the front foot, to keep the nose down at high speeds.
YPC -> RE: RC Surfer (2/4/2013 7:15 AM)
Howzit Curls !
An interesting subject.....One that 'matters' and is well worth discussing.
Let me start by saying this is only my 'MO' based of 'my experience over the past year.
Its been very interesting to me, that for many of us, 'much focus' has been placed on getting the board to run absolutely flat 'at speed, on flat water - BUT- to achieve this - just about all the ideal, much wanted surfing attributes of the boards design have been negated in the process, by the various changes i.e...no positive tail rocker - forward CG - wider tail - sharp tail rails....JIMI rocker etc......
I myself have tried most of the above concepts on my various boards and found that although the board does run flat on flat water at speed......it loses much of the ideal surf performance on a wave face........
The main point to always consider is that 'we ride waves' - not flat water ! so how we set the board up should be with the wave face in mind.
When ridding a wave face......the shape of the running surface if different ( radiused) and the plane is elevated ( vertical).......Due to this.....if your CG is to far forward.....the board will pearl (nose dive) easier when driving down the face, as in effect, the CG will be shifted even further forward, pressing the nose down. Added to that, if their is no positive tail rocker, or you have added width to the tail, sharp edges or JIMI rocker, the tail of the board will be lifted up easier and sooner, pressing the nose down further, intern initiating the dreaded pearl even 'sooner'........making one look like a grom........LOL
Many of the boards modified to 'run flat' still do ride the wave face well - but - more so when ridding parallel to the length of the wave face, as in barrel ridding , straight down the line etc. I did find though, when wanting to pull a few moves of the lip in the tighter hollower sections and come straighter down the face, that the board would often pearl quite easily
Added to that, the ridding aesthetics of the turn is also all important to me - I like the tail to drop in the turn, which is not possible with a modified lifting tail....or forward CG....hence many boards turn very boat like (upright and flat)
In my last two builds I have narrowed the tail for less surface area to reduce lift and started reintroducing positive rocker in the tail. a small amount in the previous board and a tad more in this build......At WOT ( wide open throttle) on flat water both the boards tend to skip over the water surface at speed - BUT - on the vertical wave face they certainly seem to perform better overall. Yesterday, in some healthy onshore conditions, I could see that the added tail rocker in my latest board helped me ride out of some vertical situations that I would have otherwise pearled.
Another difference I now apply to reduce the skip is, rather than have a very forward CG.....is to rather make the board heavier overall, maintaining a aft CG of 40% , so that it displaces more water... now when on the wave face, the CG will still be further back, reducing the risk of a pearl on the hollow.
It matters less how we look getting to the wave - what matters more is how we look on the wave.
Bro rcSurfer. ...
Share the STOKE !
InDaTube -> RE: RC Surfer (2/4/2013 8:07 AM)
YPC
On this topic.....
Again, board design is very important..... but how you surf your board is really key.
For instance, just like real surfing, pearling can be avoided by adjusting your trim to
raise the nose up when taking off on a steep wave.
I was having trouble pearling when coming back down the face after an off the lip or cut back.
MJ showed me that all I have to do is not give up on the cut back and not backoff the trigger during the turn.
Bingo, now I just stab the trigger when finishing the trick and boom..... the nose comes up, the tail carves in and I'm ready for the next S turn on the face. The instant punch of a 455 prop sure helps.
My MauiRCsurfer is 34" long x 10.75" wide, weighing 8.1 lbs RTS. Modest nose rocker. Pin Tail with very little "V" and tail rocker. The trailing edges are super sharp. This tail configuration carves, releases and holds the arch of a turn like crazy............ But only if I surf well !!!
InDaTube
surfkiwi -> RE: RC Surfer (2/4/2013 8:09 AM)
Thanks for the advice. I have been going back through the forum to try and work out what everyone's setup is, taking special note of what Jimi has said.
Here is the list of bits I am planning to order. Is all this going to work together? I am new to this RC stuff so would appreciate any feedback.
I also couldn't find much info on the servo to get. I found one below, but not sure if this is suitable.
A compiled list of what to get for a stock NQD would be a great idea!
Cheers,
Mark
Hobby King GT-2 2.4Ghz 2Ch Tx & Rx
3660SL 3180kv Brushless Inrunner
HobbyKing 90A Boat ESC 4A SBEC
Turnigy 6000mAh 2S2P 7.4v 25C hardcase pack
Hobby King Digital Servo 2.2kg / 12.5g / .11sec
YPC -> RE: RC Surfer (2/4/2013 8:25 AM)
Indatube...........absolutely..........if it was easy, everyone would be doing it right...also.... don't forget.......you have started with a great board.....with all the attributes...
MJ has a degree of positive rocker in his builds and the slight v toward each rail also introduces added positive rocker at the tail in nett effect. The board weighing 8 lbs RTS will have good displacement reducing the hop and skip across the water.
Bro rcSurfer. ...
Share the STOKE !
Page: <<   < prev  248 249 [250] 251 252 253 254 255 256 257   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.34375
