Paolo.75
Joined: 5/18/2006 From: Oristano, ITALY Status: offline
Hi Micha, your German friends advices are wrong. I means rpm/volt, I use a brushless Jeti Phasor 15/3, 2500 rpm/volt, 2500rpm x 8,4 volt (7 cells battery) = 21000 rpm and goes well. Someone use motors with 3500 rpm/volt and goes well already, but you must use a smaller prop like a 27mm (I use a 30mm brass prop with mine). A very used motor is the Mega 22/20/2, is about 2800 rpm/volt, it's very fast, so a brushed motor with 2800 rpm/volt is perfect. You must replace the transmission with a Graupner GR321 o with a flex transmission. My Kyosho weight is 1,7kg, the NQD covered in carbon fibre 2,1kg, both with 4AA receiver battery pack. The NQD board is heavier however. I don't know wich speed they get. If you can, get bruhless motor!
< Message edited by Paolo.75 -- 10/22/2007 5:57:48 PM >
_____________________________
www.paolocarta.3000.it - surfing photos in Italy www.surfradiocomandato.4000.it - my RC surfers
