Paolo.75 -> RE: RC Surfer (1/31/2008 12:43 AM)
Hi Tomaz, more turns: - speed, + torque; less turns: + speed but - torque (and more battery consumption). The motors that you've indicated aren't good, the RC Surfer needs a motor between 2500 and 3500 rpm/volt. Are very good: Mega 22/20/2, Hacker B40 series (8L or 9L), Jeti Phasor 15/3 or the cheap Feigao that you can find on http://www.offshoreelectrics.com/. If the RC surfer goes for 10 min with a 1500 mha battery, it will go for 20 min with a 3000 mah one! I use a GP3700 7 cells, I usually run for about 25 min putting gas when the good set arrive only, and returning on the line up at 1/2 gas....let see my video: http://www.youtube.com/watch?v=IWQuv1P-kX4 Regards Paolo
