gnarbrah
FL, USA Status: offline
Yeah, you're much better off gutting it completely. It gets slightly tricky once you pull off that stuff above the motor. There's a circuit board which is probably the receiver, speed control, safety (prop only moves when its in water, thats those two screws with the little green wires going to them) mounted right to the front of the motor which takes a little coersion to get out. I ended up just bending it back and forth till most of it broke then got in there with some dykes and cut out what was left. I'm assuming you're going to put a esc in right? If thats the case don't worry about hurting anything, its all going in the trash anyway. Just watch the 2 little tabs on the front of the motor that you need to solder the new esc to. After all this is said and done (look at my previous pic) you'll see its going to be alot easier to work on, change out motor and whatever else. Not to mention it will actually work! Post some pics as you go if you can btw - I'm still hoping for some good info on which 19t would be good (without breaking the bank) I saw a kimodo dragon for like $30 on tower. Is that any good? Thanks
