wbf1mad
Joined: 1/30/2005 From: bolton, UNITED KINGDOM Status: offline
quote:
ORIGINAL: dacaur all I can think of is to make sure you have water going through the heatsink... where is your water pickup? The way you describe it, it sounds like the esc just cant handle the amp draw when you hit full throttle. There is way more resistance to the prop turning in the water than in the air, which would explain why its fine when its out of the water... looking at the specs for the price of that ESC, I would say its probably pretty cheaply made, not cheap like inexpensive, cheap like crappy.... Those are some pretty high numbers for such a low cost esc... If it were made by a reputable company I would expect it to cost $100 at a bare minimum.... So either the esc is not actualy able to handle what its "rated" at, Or you just got a defective one... You might also try swapping out the motor, but I suspect the esc is the problem, cheers, ill take it back. i did say if it could not handle the job id be back for a refund.
