RE: Club Laser?
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  7/13/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club Laser?
Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
Login
RE: Club Laser? - 3/22/2007 3:15:10 PM
jjmretired
Status: offline
Dave, Got the 180 yesterday. There is a updated instruction sheet (from the 70). It says max of 10,000 rpm for the 70. you might want to load it a hair more.
(in reply to Kmot)
       Post #: 51
RE: Club Laser? - 3/22/2007 4:50:51 PM
Hobbsy
Status: offline
Thanks Jay, I was surprised at its power, especially on 5% nitro, most likely I'll run a Bolly 13.5x6, now for a plane. I take it that your 1.80 is a single, mine is a twin, let us know how it goes.
_____________________________
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
(in reply to jjmretired)
       Post #: 52
RE: Club Laser? - 3/22/2007 9:08:34 PM
Marcol
Status: offline
The carb used on the West 4 strokes is a Webra unit
(in reply to Kmot)
       Post #: 53
RE: Club Laser? - 3/22/2007 9:17:55 PM
Marcol
Status: offline
Guys,
Don't be afraid to load the Laser up with a big propellor. It's got torque by the bucketfull.
I run a 13 x 8 on my 70, so a 13.5 x 6 will be fine.
Because the Laser doesn't rev it's ass off people assume that it's lacking in power. But as we in the club know this isn't the case.
(in reply to Hobbsy)
       Post #: 54
RE: Club Laser? - 3/22/2007 9:58:02 PM
Hans Meij
Status: offline
This is a recommendation from Laser:
LUBRICATE through the BREATHER NIPPLE on the rear of the crancase before and after the initial running in and after every 3 hours running. Lubricate the engine if it is not to be used for some time and before running again. The breather nipple can be extended with tubing. Oil may come out of the front bearing if the breather is restricted, there is a lot of oil in the crankcase or the engine is left with the nose down. This will not harm the engine.
Have for a laser 150 in operation for two years now. It works great.
Use 15% Aerosave oil and 8% Nitro, engine pointing down.
From time to time I pull the valve cover to check for valve clearance.
No problems, and everything is filled with oil there and no spot of corrosion.
Because the engine is leaking oil everywhere when it is stored after flying I know it must be lubricated well inside, and that is confimed every time when I open up the cover.
A month ago I started using the 200V engine. Filled it with a amount of oil through the breather when used the first time.
After that I did not apply extra lubrication the same way as I did with the 150.
It has a gallon through it and I noticed that it was loosing power when becoming warm, and was not as powerfull as in the beginning.
Today I pulled the valve-covers. It was quite dry inside, and one of the two spaces had the brownish muddy debree of corrosion inside.
So perhaps something to be aware of, it seems that, especially the twin, needs the insertion of oil through the breather before ande after flying sessions.
(in reply to Marcol)
       Post #: 55
RE: Club Laser? - 3/23/2007 3:41:41 AM
Kmot
Status: online
quote:
ORIGINAL: Marcol
Thank you.
Ahhh......screw it!
       Post #: 56
RE: Club Laser? - 3/25/2007 5:49:21 PM
Marcol
Status: offline
Hans,
As you are using aerosave oil, as I do, you shouldn't need to use any other corrosion protection.
On the last run of the day I throttle up to full power for about 30 seconds to get the engine hot and then run the engine dry. Either by pinching the fuel line or disconnecting it.
The Aerosave oil offers the best corrosion protection of anything I have tried BUT, you must NOT mix it with a mineral based oil .
This could be some of your problem with your 200V.
(in reply to Hans Meij)
       Post #: 57
RE: Club Laser? - 3/25/2007 6:56:13 PM
Hans Meij
Status: offline
quote:
ORIGINAL: Marcol
No only Aerosave. What I've mentioned, the V-engine somehouw does not collect oil as a result of normal operation under the valve cover. After a day of flying it is dry there. After a flying day you have to insert a few cc's of oil through the breather. This will enter the room of the valve cover and will give the corrosion protection. This is what I have experienced with the V-200
       Post #: 58
RE: Club Laser? - 3/27/2007 8:08:17 PM
Marcol
Status: offline
Hans,
Is your 200V mounted inverted or upright ?
Colin
       Post #: 59
RE: Club Laser? - 3/27/2007 8:27:20 PM
Hans Meij
Status: offline
Hi Colin,
It is mounted inverted.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 60
RE: Club Laser? - 3/31/2007 11:33:57 PM
TLH101
Status: offline
I just picked up a Laser today at an estate sale. I think its a 1.50. It is stamped P-22, on the mount rail. Can anyone tell me for sure?
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by TLH101 -- 3/31/2007 11:34:46 PM >
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
       Post #: 61
RE: Club Laser? - 4/1/2007 3:29:34 AM
Hobbsy
Status: offline
http://www.laserengines.com/
According to the pics here the 1.50 and the 3.00 twin have the purple carbs.
(in reply to TLH101)
       Post #: 62
RE: Club Laser? - 4/1/2007 7:18:40 PM
TLH101
Status: offline
Yeah, I looked at their website, and that's why I think I have a 1.50. Weight and hieght seem to mach as well, but I notice the newer models have more "rounded" shape than mine, so I just trying to confirm. I also noticed earlier in the thread, someone mentioned a purple carb on a .70, I think it was. This one came from the estate of a local flying buddy, and I'm pretty sure he had it for at least 10 years.
Terry
       Post #: 63
RE: Club Laser? - 4/22/2007 10:33:13 PM
TLH101
Status: offline
Well it must be a 1.50. I ran it today and with an old 16x10 Classic prop it turned 8600 rpm. Saw up over 9K with a 16x8 APC, but could not get a good tach reading from the grey prop with the cloudy conditions today. Idle would tick over at 15-1600rpm. I was using Byrons 15% with 16% oil. This has to be the smoothest running four stroke I have ever run.
BTW, the guys at Laser said it was built in '96 or '97, based on the numbers stamped on the mount rail.
I need to get this puppy something to fly soon.
Terry
       Post #: 64
RE: Club Laser? - 4/23/2007 1:50:49 AM
PlaneKrazee
Status: offline
Looks like Moki is making an exact copy or licensed version of the Laser engines.
http://www.remekmotorok.net/index.htm
KB1DTB
AMA11123
