RE: Club Laser?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Club Laser?
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: Club Laser? - 4/28/2008 8:56:59 PM
summerwind
Status: offline
can't believe my luck. i was all set to run both my 80 and 200V this past weekend, and then came down with the flu of all things..........oh but today i feel 100% better...........this weekend it will happen though, and right now i have K&B1L plugs installed in both engines for test stand running, but i will be switching to the OS F plugs, so i'll take some reading (mostly at idle) and report to which works the best.
i'll be using Cool Power 10% as it's all synthetic.
(in reply to Marcol)
       Post #: 126
RE: Club Laser? - 4/29/2008 12:02:40 AM
JET FX
Status: offline
Yes I meant to type Laser 360.... thats what happens I guess when posting late at night and being half a sleep
Anyone have experiance with the 360?
Cheers- Marty
< Message edited by JET FX -- 4/29/2008 12:04:26 AM >
_____________________________
JET FX Australia~ Cosmic Pilots, Jets Munt, Yellow Aircraft, Sis-T, Fei Bao, Fly Eagle Jet, Wren- www.jetfx.net
(in reply to summerwind)
       Post #: 127
RE: Club Laser? - 4/30/2008 9:17:05 PM
Hobbsy
Status: offline
I found a home for my LASER .70, it ain't purty but I enjoy flying this plane, I have flown the Kombat 60 with an Enya .46 MKII Saito .80, Saito 1.00, Fox .60 and .74 both as glow and Diesel and now the LASER. It turns a Graupner 12x7 at 10,300 on WildCat 5% Premium/16% lube that is 80/20 syn castor. A GloDevil 4c Special is the plug. This is an older LASER with clamps holding the carb and muffler instead of grub screws.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
(in reply to fiery)
       Post #: 128
RE: Club Laser? - 5/1/2008 7:48:50 AM
Bosse
Status: offline
Thank you for your answers, I found out when looking more close to what I've done to the engine that I was way off with the valves, instead of .002" - .004" I had about .015".
Have put an OS F plug in and moved the tank 3" forward, hopefully I will assembly to night and crank it later tonight.
If you want your dreams to come true, you have to wake up first.
(in reply to Hobbsy)
       Post #: 129
RE: Club Laser? - 5/1/2008 7:30:56 PM
Marcol
Status: offline
quote:
ORIGINAL: Hobbsy
No,it's the other way round. The older Lasers had the grub screws. The newer ones have the clamps.
       Post #: 130
RE: Club Laser? - 5/1/2008 11:19:39 PM
Hobbsy
Status: offline
Thanks, I had a 1992 Laser 1.80 V-twin and thought perhaps this .70 was older, perhaps not though.
       Post #: 131
RE: Club Laser? - 5/5/2008 5:54:32 AM
Bosse
Status: offline
I can only say, holy crap what an engine to run smooth . I don´t know if it was the valve setting or the change to a F plug but the engine ran like a train, it didn´t matter what i did with the plane in the air, the engine just went on like a dream with no fuzz what so ever and that is in a 3D profile plane that can do a spin in insane speeds. Now I´m just waiting on my tachometer so I can get som rpm readings. Laser is an engine to salute.
< Message edited by Bosse -- 5/5/2008 9:52:36 AM >
       Post #: 132
RE: Club Laser? - 5/10/2008 10:22:27 PM
Bosse
Status: offline
Well I finally got my tacho readings today and with an 13x5 Masterairscrew, 10% Cool Power with 17% oil I got about 10300 rpm, now I'm awaiting my APC 14x4W and see if it's any difference that is worth the extra money for the prop.
< Message edited by Bosse -- 5/10/2008 10:23:33 PM >
(in reply to Bosse)
       Post #: 133
RE: Club Laser? - 5/19/2008 10:03:15 AM
JET FX
Status: offline
No 360 owners out there?
What about Laser 180 owners then, on yet another project I have Iam considering replacing a Moki 1.8 in my Brian Taylor 1/5 Spitfire with a Laser 180. Question I have is what is the overall hight of the 180 from center of crank to top of rockers??? need to fit this within the cowl if its going to work...
Cheers- Marty
(in reply to Bosse)
       Post #: 134
RE: Club Laser? - 5/24/2008 12:14:58 AM
jjmretired
Status: offline
Marty, I have a Laser 180 in a Nieuport Triplane (page 4 of this forum). I can't get to the engine to measure at this time, we're moving, but it's approximately 5". The engine is perfect for the 17 lb triplane but it won't be as strong as your Moki 180.
(in reply to JET FX)
       Post #: 135
RE: Club Laser? - 7/29/2008 3:41:56 PM
jjscott
Status: offline
I picked up a Laser from Canada off ebay. I believe it is an early 62. Bore measures about 0.94". It was sold as having no compression, and, when received, it didn't. I put a prop on, flipped it and got nothing.
I pulled the head, shot carb cleaner in the valve seats, pulled the cylinder and looked at the liner. It shows signs of use, and when I hold it up to the light just right I can see a shadow of wear up at the top where the piston changes direction. I put it back together; it seemed the ring had very little tension. It just slipped up into the liner without a lot of squeezing.
After some 10w-30 oil in the cylinder I flipped it again. It now has compression, but it doesn't seem like a lot.
I'm sure Frank Bowman can make a ring. I'm wondering about the liner and if anyone knows whether Laser can supply parts for this old motor. It has the initials for a serial number.
Has anyone ever taken one completely apart? I don't see how the cams are timed. I posted on the British forum and got a reply that there is a mark on the crank side where the sdmall gear gets driven. I don't want to take it down and lose the timing. But it should come apart. It's dirty inside and needs a good clean.
Jim
Click for fullsize
Click for fullsize
(in reply to jjmretired)
       Post #: 136
RE: Club Laser? - 7/29/2008 3:45:52 PM
summerwind
Status: offline
jj,
i'll bet if you email Neil he'll get you what you need.
(in reply to jjscott)
       Post #: 137
RE: Club Laser? - 9/7/2008 8:22:31 PM
mosfbv
Status: offline
Hi all, I finally got my Laser 120 run in and flight tested in my Astra Hog...By far the best 4 stroke I have owned, Throttles and sounds brilliant.
If you want to see it during part of the running in period type in LASER120 into youtube. Hopefully I will get some in flight video posted soon aswell.
V
       Post #: 138
RE: Club Laser? - 9/13/2008 5:26:58 AM
Woody 51
Status: offline
I have 2 x Laser 100's.
One is earmarked for a VQ P40. Not sure about the other.
I also have an unbuilt Blackhorse .60 sized T-18 Trojan, but a Laser 100 may be a little over the top for this model.
A crash keeps one's opinion of one's flying ability, in perspective.
(in reply to mosfbv)
       Post #: 139
RE: Club Laser? - 9/14/2008 9:53:31 AM
flyingbells
Status: offline
Hi,
I'll join! I'm the owner of a Laser 150 since 2003.
It had been on 25% Funkey Cap232 but had a mid
