Marcol
Joined: 3/23/2006 From: King's Lynn, UNITED KINGDOM Status: offline
Count me in. I have the following sizes - 62 , 70 , 75 , 2 x 80 , 150 , 240 V Twin. They are all, without exception, THE best 4 stroke scale engine made. If I may be so bold as to offer some advice. You will find that the best plug for the Laser is the OS F. Only use a fuel containing no more than 15% SYNTHETIC oil. Please don't use castor oil. The designer , Neil Tidey, states that castor oil should not be used as the bulk of the lubricant. 20% oil is too much and 20% castor oil is just bad news for any engine. Although the Laser will run quite happily on straight fuel a little bit of nitro is beneficial to any glow engine. I run all my engines on 10% Prosynth 2000. This fuel contains Aerosave oil as the lubricant and is one of the fuels recommended by Laser. It great to be a part of THE BEST club
