RE: 42% 260 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: 42% 260 Build
Page: <<   < prev  1 2 [3]
Login
RE: 42% 260 Build - 4/16/2007 12:09:52 AM
Mark Dennis
Status: offline
Alright well I finally have time to get some pics up of my progress. The plane was actually at the Toledo show for the week so i wasnt able to work on it but here are pics of what i got done before it left. I got the rudder glued on, the only gluing I have done on the entire plane. I also installed the 2 5955's in the tail and got there linkage hooked up. This should work well and will provide plenty of rudder authority.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Team Aeroworks
Thank You: Aeroworks, Desert Aircraft, and Smart-Fly
(in reply to Mark Dennis)
       Post #: 51
RE: 42% 260 Build - 4/16/2007 12:12:19 AM
Mark Dennis
Status: offline
I also got all of the graphics on the plane. These are the ones that came with the plane and look great!
Click for fullsize
Click for fullsize
Click for fullsize
Team Aeroworks
       Post #: 52
RE: 42% 260 Build - 4/16/2007 1:51:27 PM
kredge540
Status: offline
Does anyone know the stand-off lenght for a 3W 150 for this plane?
       Post #: 53
RE: 42% 260 Build - 4/18/2007 1:39:56 PM
kredge540
Status: offline
Mark,
Can you possibly find out from Sean McMurtry what the stand off lenght is for a 3W 150 please.
Kevin.
(in reply to kredge540)
       Post #: 54
RE: 42% 260 Build - 5/5/2007 7:41:07 PM
riotgear
Status: offline
Any new progress on this plane? Also, will it ever be offered in any other scheme?
       Post #: 55
RE: 42% 260 Build - 5/6/2007 7:16:41 AM
bodywerks
Status: offline
quote:
ORIGINAL: kredge540
Mark,
Kevin.
mount the cowl, measure the distance fron the engine firewall to the front of the cowl and add 1/8" for spinner spacing. Write that number down, the measure the length of the engine and subtract that number from the number you wrote down. The result is the required length for the standoffs.
STRAIGHTEN UP AND FLY LIGHT!!!
       Post #: 56
RE: 42% 260 Build - 5/10/2007 2:07:15 AM
Mark Dennis
Status: offline
Well since schools been winding down i've had more time to work on this thing. I got the batteries and reciever in along with the tank. Im using 2 5200mah Fromeco batteries along with a single 2600mah for the ignition. I'm running a single JR R2000 reciever. The tank is the 50oz that came with the plane and I used all of the stock hardware for the tank. The velcro straps are included as well.
Click for fullsize
Click for fullsize
Click for fullsize
Team Aeroworks
(in reply to bodywerks)
       Post #: 57
RE: 42% 260 Build - 5/10/2007 2:11:00 AM
Mark Dennis
Status: offline
I also got the throttle servo setup and programed. I used a 5945 along with a titanium link.
Click for fullsize
Team Aeroworks
       Post #: 58
RE: 42% 260 Build - 5/10/2007 2:19:53 AM
Mark Dennis
Status: offline
I took the cowl apart and mounted the bottom half. You can see how well the baffeling has been installed as well as how well the mounting has been done. Each screw goes through a ply rienforcement block and into a blindnut. This setup is very strong and does not add much weight to the overall cowl. You can also see the lip that the cowl sits on this was all done out of the box, the only thing I have done is unbolt the top from the bottom.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team Aeroworks
       Post #: 59
RE: 42% 260 Build - 5/10/2007 3:39:32 AM
WarbirdAirRacer
Status: offline
Hey Mark, That baby is looking SWEET! Cant wait to see it on Sunday if I head out to crosswinds.....
Tat-Tude 379
       Post #: 60
RE: 42% 260 Build - 5/10/2007 11:02:52 PM
Mark Dennis
Status: offline
quote:
ORIGINAL: John@Aero-Works
Its getin there! I should have it ready for Saturday as long as nothing major comes up between now and then. All thats left to do is button up the cowl and prograhm and she's good to go!
Team Aeroworks
(in reply to WarbirdAirRacer)
       Post #: 61
RE: 42% 260 Build - 5/11/2007 4:33:59 AM
flstn95
Status: offline
Mark,
How did your CG come out with your equipment as shown on your thread?
flstn95
       Post #: 62
RE: 42% 260 Build - 5/11/2007 5:44:23 AM
Mark Dennis
Status: offline
As a matter of fact I just finished checking it! It came out dead on at 4 1/4".
Team Aeroworks
(in reply to flstn95)
       Post #: 63
RE: 42% 260 Build - 5/14/2007 3:04:38 AM
falconpilot
Status: offline
Here guys,
I test fly my 42% QB 260 yesterday and thought that I'd give a quick report. Just as Marks, my airplane came out dead on CG wise at 4 1/4" inches. I'm running the same setup as Mark with the expection that I'm running three servos per Ailerons. I have'nt weighed it yet, but I can tell you that it feels about the same weight as my Dalton with is 37.4 pounds. I'm guessing 38lbs, but I'll get a hard number soon.
The airplane went together without a hitch, as per Aeroworks plans. I really like the Aileron setup instruction when running three per wing. AW tell you to connect the inboard control to the bottom hole on the horn, the middle the middle hole, and the outboard the top hole. Using this setup provide for great geometry, and minium programming. Very impressed witht the thought that went into the instructions! Everything fit excellent in this kit. I didn't have to change or adjust anything. I would suggest that when you recieve your kit that you bolt the hatch to the airplane anytime you are not working on it. Otherwise as the airplanes wood dries with the hatch off, it'll result in a very snug, tight fit when you replace the hatch. Leaving in on all the time until it the airplane dries good insures a good fit. The wing tube fit wasreally tight due to the tube being carbon fiber, and the sleeve glass. It required a little sanding, but nothing hard. I've been told that this has only been an issue with a few kits.
To the flying!! Just let me state that after one day of flying, it will now be my competition IMAC machine!!! What a great flying airplane! It rolls better than any airplane that I have ever flown. This is a very, very, very impressive airplane, espically considering its an ARF, and priced very reasonably! The airplane flies like an airplane should with no weird tendencies. It's rolls are unbelievable, it's snap super precise, start and stop now!, it's roller very easy with no wondering. This is the airplane that I have been looking for to compete with.
Bear in mind that with Aeroworks recommanded CG, you'll find that the airplane is actually too nose heavy, but I understand from a company standpoint that they must err toword the safe side here.
As far as mixing goes, I have no more than 4% anywhere even with the airplane more than a little nose heavy. All the mixing that I have would be required of a nose heavy airplane, so Iexcept to have very little mixing once I get the CG right.
For all you guys setting on the fence, you can get off on this side because you CAN NOT go wrong with the airplane. WHAT a value!! For those of you that are IMAC flies, stay on the fenceor get off on the otherside, becauset his airplane will make you a better pilot,and I don't need the competition!!
My other, new airplane is now offical for sale, listed here on RCU. Someone buy it so I can order another QB 42%!!!
       Post #: 64
RE: 42% 260 Build - 5/14/2007 7:11:56 AM
