Electric Delta
NC, USA Status: offline
I got a Predator II last year, and it has been a bit disappointing. The wing was not straight, it took quite a bit of aileron trim (like 3/32", i.e. like half of the total throw!) just to get it to fly straight. Surprisingly, the trim does not change from idle to full throttle. After a few weeks, the covering on the fuselage started to peel/fall off, starting at the nose. I had to re-cover the front of the fuselage, to avoid the wood getting fuel-soaked even worse. I have also flown a few Vipers, and don't care for the twitchy pitch response (even with exponential), they seem to hunt around a lot; at least in this respect, the Predator II handles better. As far as I am concerned, the market is still wide open for a really good 424 class ARF.
_____________________________
Auf die Dauer hilft nur Power! Revver Brother #127
