Another question from that Dude with the EP Concept
Tower Hobbies
Logged in as Guest
  Printable Version
HELICOPTER PROBLEMS OR NO EXPERIENCE: LET OUR STANDS AID YOU - RTR
Seller:  helisafestuff
Details:   $99.95   |  1/3/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Another question from that Dude with the EP Concept
Page: [1]
Login
Another question from that Dude with the EP Concept - 2/12/2003 7:09:39 AM
helirookie
Status: offline
Evenin everyone,
I have run into a small inconvenience that has caused me to inquire of your expertise.
I am putting together an EP Concept and it has a Great Planes C30 ESC with it. According to the instructions, yes I actually read them, there should be three capacitors and one diode on the motor to control noise from the brushes. They say that the diode will "provide a slight increase in the ESC efficiency and reduce its operating temperature." So, I am all for that.
There is one capacitor on each brush plate. I picked up the other missing capacitor today and installed it. The diode was another problem. It refers to it as a Schottky diode. There was approximately 16 different ones listed in the NTE catalog and I was not sure of the difference. Anybody have any help?
Ed
helirookie
       Post #: 1
Another question from that Dude with the EP Concept - 2/14/2003 4:44:13 AM
Thrustline
Status: offline
SOD323 or a SOD666 they are low voltage, high speed diodes used in speed controllers and the like, max voltage range of 10 volts.
(in reply to helirookie)
       Post #: 2
Thrustline - 2/14/2003 5:57:22 AM
helirookie
Status: offline
Thanks for the input. Getting really close to putting this one in the air.
Ed
helirookie
       Post #: 3
Another question from that Dude with the EP Concept - 2/22/2003 6:20:59 AM
Tippie
Status: offline
The diode that came with my GP C-30 was a SK-506. Did a seach on it to check for what the specs were and to see if there was a cross reference to it. The SK-506 is a 5 amp Schottky Barrier Rectifier.
       Post #: 4
Tippie - 2/22/2003 7:09:48 AM
helirookie
Status: offline
Thanks for the input, I may see if there is something a little higher current. Raising the cell count to 8 should lower the current some, but helis are always under load. So, thanks again. Should have this in the air by the end of the month.
Ed
helirookie
       Post #: 5
Well? - 5/29/2003 10:25:38 PM
JoeR
Status: offline
Did you ever get it in the air?
I recently bought an EP Concept (should be here any day). Would love to hear some feedback. Thanks, Joe
       Post #: 6
Another question from that Dude with the EP Concept - 5/30/2003 7:15:35 AM
u8at711
Status: offline
yea rookie, did you ever fly that thing yet?? I put my concept on the shelf and got a Corona.... I like the Corona but I think it's time to pull the Concept back out, I have been crashing because of chopping the throttle and loosing rotor speed, = You can't control a bird without the blades spinning.. Time to get my CP machine in the air.... hahhaa, last night I was at the local field, I got about 100-200 feet of altitude, I could barley see the heli, then I notice it falling very very fast, when I realized it was inverted,, quickly chopped throttle, that slowed the machine down allot, then blades still spinning no power I got it on its side, forgot to bring the rotor speed back up, fell like a rock. It bounced about 6 feet in the air when it hit..... damage report::::: broke glue joint for the landing gear... broke battery mount... fixed with CA glue.. Corona's can take a beating.. this machine is fixed pitch I think thats why I could not recover. Mike
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU5
