TEMPS!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Schumacher R/C Superstore Support >> TEMPS!!!
Page: [1]
Login
TEMPS!!! - 3/4/2007 5:32:00 PM
finishline
Status: offline
At what temp should the Rascal run at? because mine does not seem to run well unless it is around 300! Only having a single gear makes the rpm's run to high i believe. Would the 2 speed conversion kit help it run cooler, faster,and overall better?
       Post #: 1
RE: TEMPS!!! - 3/4/2007 6:14:19 PM
Groundman
Status: offline
Is it the stock plug ?
_____________________________
Never argue with someone of lesser intelligence, they will beat you with experience every time !
(in reply to finishline)
       Post #: 2
RE: TEMPS!!! - 3/4/2007 6:29:40 PM
Groundman
Status: offline
On the .21 head temp should be around 270 , i am not sure on the rascal
(in reply to Groundman)
       Post #: 3
RE: TEMPS!!! - 3/4/2007 9:34:14 PM
Schumacher RC Superstore
Status: offline
You may have an air leak. You should be able to get great power from 230-260 degrees. Check your fuel tubing and the fuel tank for leaks.
Schumacher-rc.com | HavocRc.com | RascalRc.com
       Post #: 4
RE: TEMPS!!! - 3/6/2007 4:30:24 AM
finishline
Status: offline
I have no air leaks all is good with lines. Rascal is so hard to control in the dirt is there any thing other than downsizing the engine for more control on dirt. No fun running at 1/4 - 1/2 throttel!!!!!!
(in reply to Schumacher RC Superstore)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.252RCU1
