TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!!
Page: [1] 2   next >   >>
Login
TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/4/2007 11:21:24 PM
UltraDrifter
Status: offline
HI GUYS,TODAY I HAD MY FIRST RUN WITH MY NEW TT-01 AND IT WAS INSANLY SLOW,WHY?I DONT THINK THAT CAR CAN EVER DRIFT AT STOCK SETTING.I DIDNT USED DRIFT TYRES AND I DONT THINK THAT WAS THE ONLY FAULT!TOO SLOW I WAS DISSAPOINTED...,
       Post #: 1
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/4/2007 11:40:33 PM
fugadude
Status: offline
You need to probably try the drift tires, because the car isn't supposed to be fast, just torqy so you can get that wheel spin.
(in reply to UltraDrifter)
       Post #: 2
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/4/2007 11:53:25 PM
UltraDrifter
Status: offline
I hope so because it was stuck on the ground with the stock radial tyres.Do you ever had a tt-01?I''ll try to run it with the front drift* ones setted on the rear wheels. *(from my nitro stage d car).I wish to drift a little
(in reply to fugadude)
       Post #: 3
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/4/2007 11:58:52 PM
RCamo-dk
Status: offline
r ur battery's charged???
_____________________________
TT-01 Black 350Z
The DK of Nobel MS
       Post #: 4
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 12:04:15 AM
UltraDrifter
Status: offline
Yes man,my baterries are new too!I think it depends only on the tyres i use.But is true that i expected faster...
(in reply to RCamo-dk)
       Post #: 5
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 12:37:29 AM
lnc0321
Status: offline
Which battery are u using? I bought a Himoto and when I first ran it with the stock battery it was very slow. I change the battery to a venom 7.2v 3000mah and wow what a difference.
       Post #: 6
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 12:41:57 AM
poe
Status: offline
I had fun putting electrical tape over the stockers and drifting with that.. Now that i have a new motor I can drift without the electrical tape on those tires.
hey baby
(in reply to lnc0321)
       Post #: 7
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 12:56:58 AM
magnat
Status: offline
Ultra, Can you get a Vid of Your TT-01 in action as something is Severly wrong..
Here is magnats TT-01 STOCK (Alloy propshaft and Bearings only)
http://media.putfile.com/Lost--my-Mind
All He Uses is Polypipe Tyres
(Yes he did write the music using his PC and a game Called Music 2000)
Believe it or not but the Lancer shell in his Vid used to be a HBX Lancer..
< Message edited by A.U.S.O -- 3/5/2007 1:03:57 AM >
Traction: What a drag.....
(in reply to poe)
       Post #: 8
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 1:50:34 AM
C.A.R.
Status: offline
Look you need to chill out!
The TT01 is a toy, with hobby grade electronics. If you wanted something fast you should've bought a TA05. For drifting a TT01 is a great gateway, and it is there to be modified. If you've driven only a nitro car before, you could've expected the TT01 to be slower. It was built for the kids who grow out of the Tamiya Quickdrive cars.
A TT01 is the slowest Tamiya hobby-grade car you can get. But for fun and reliability, it is one of the best.
Chris.
(in reply to magnat)
       Post #: 9
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 2:04:55 AM
magnat
Status: offline
TA-05's are no quicker they use the same electronics..
They handle better but are no faster
(in reply to C.A.R.)
       Post #: 10
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 11:43:36 AM
infernox
Status: offline
ta is faster, light chassis
my yokomo in stock form will beat and stock tt01 coz its lighter and more efficient.
tt is slow when stock, thats the thing!!!
Seigi Drift Crew South Africa
www.truevision.co.za
       Post #: 11
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 12:45:28 PM
fl0PPsy
Status: offline
The TT-01 drifts fine stock but you do need to use the right tires. If you use the rubber radials that came with the kit then of course its not going to slide.
4 x TA03F Pro-2 x TA03R-TA05MS-ProD-Micro RS4 Drift-Sprint 2 Stage D-MR4TC SD CM-TT01 CF Converted-Dark Impact-Frog-Lunchbox
(in reply to infernox)
       Post #: 12
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 1:45:23 PM
UltraDrifter
Status: offline
When i have time i'll take it a video to see..I had seen a lot of videos in the web with TT-01 going really mad and sideways ...
(in reply to fl0PPsy)
       Post #: 13
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 3:11:36 PM
Flaming Tire
Status: offline
Hold on, and new battery is NOT a charged battery. Make sure you charge it before you use it! Thats my 2 cents
Check out www.maxamps.com
       Post #: 14
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 5:00:21 PM
joeyblaze
Status: offline
The TT-01 drifts fine with some minor mods, i have the TT-01-R which has the minor monds done in stock form.
Alum Shaft, Bearings. The all you needs i ABS tires and you can drift to the cows come home. I think you are trying to drift with rubber tires on.. get some ABS.... u dont need speed to drift.
(in reply to Flaming Tire)
       Post #: 15
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 10:09:31 PM
C.A.R.
Status: offline
quote:
ORIGINAL: A.U.S.O
Wrong. Don't give out false information.
Chris.
       Post #: 16
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 11:15:16 PM
fugadude
Status: offline
UltraDrifter
have you tried the electrical tape idea, tell us how it goes when you put some drift wheels on there. You can get a set of 12 really cheap and tight fitting on ebay.
       Post #: 17
RE: TT-01 I DONT THINK THE STOCK CAR CAN EVER DRIFT!!! - 3/5/2007 11:33:05 PM
