sturmgrenadier
Joined: 12/12/2007 From: Great Falls, VA, USA Status: offline
I had something weird happen yesterday. I recently broke-in the engine on my NTC3. It has been starting and running fine. I an through one tank. Then after I refueled, the car it started acting strangely: accelerating from dead stop, the car started yawing violently to the right, in a circle, not quite spinning in place, but making a very tight circle. I tried steering the wheels to the left (visibly pointing hard left) before accelerating, but the car was still pulling fiercely to the right, circling. I picked up the car, hit the throttle and everything looked normal (no debris jammed on one axle, etc.) I couldn't for the life of me figure out why it was behaving like this. I took it into my local hobby store (LHS) and a friendly tech checked my car out, advising me that the rear differential was fine. We started it up in front of the store, without making any adjustments, and the car ran just fine without any of that crazy yawing to the right. I was dumbfounded.....The only thing that the tech suggested might have explained the problem I had was weak receiver batteries. he advised that I replace them, but they still seem to have enough 'oomph...; when steering. So I don't think that was the problem. One other thing problem that I have is that my throttle doesn't move the car until the trigger is depressed by at least 1/3rd. One other forum member suggested that I try leaning out the low speed needle, but after turning it a full 1/4 clockwise, I am not seeing any appreciable difference in how my throttle responds: It only revs up for the first 1/3rd of the pull... Any other ideas or explanations? Thanks folks.
_____________________________
"Due to fiscal constraints, the light at the end of the tunnel has been extinguished indefinitely. Watch for oncoming t
