hpi apollo
KY, USA Status: offline
you probably mean the mid speed needle, usually you dont have to touch those much, just make sure you have good airflow, that your engine is sealed from airleaks, using a good fuel, and tuned for a clean, crisp throttle response and dont worry about the temps, its a v-spec, a racing engine meant to deal with some heat, i would say 260 while racing isnt bad
_____________________________
95% of statistics are made up on the spot
