vladconnery
NC, USA Status: offline
quote:
ORIGINAL: hpi apollo i would use something other than blue thunder, fuels with high/higher amounts of castor oil are a bit more forgiving at tuning, vapor lock can be caused by an engine that is running lean, inadeqaute airflow, or both, you can use blue thunder if you want, i would get some castor oil and add it to the fuel, not a big deal, and they run much cooler, when i made my own fuel for the first time, i used 10% straight castor oil and my engine had to be leaned over a full turn to run right, then it was flying and running cool Apollo, What fuels are high in castor, I use trinity monster HP 20%. Can you do a post on how to make your own fuel? Oh and excellent thread it was really insightful. Don't worry if people didn't give you grief about your how to guide it wouldn't be good guide. Fix a car for someone and they will be back in an hour. Teach them how to fix it they will be back in an hour with a new problem.
_____________________________
Nomadio, LOSI 8IGHT B, RB S3 L2G, RB WS7 III, Go Tech 7p
