Buying Castor - which type?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Buying Castor - which type?
Page: [1] 2   next >   >>
Login
Buying Castor - which type? - 3/6/2007 12:57:39 PM
Patxipt
Status: offline
Hello all.
I've been told of a local chemist warehouse where they sell castor oil. What kind of oil am i expecting to buy for mixing fuel for our model engines? Is pharmacy castor good, or what other type of castor must i ask for?
Thank you
_____________________________
Modelling regards,
Francisco
       Post #: 1
RE: Buying Castor - which type? - 3/6/2007 5:20:37 PM
Motorboy
Status: offline
These castoroils are good enough for model engines.
Jens Eirik
Jens Eirik
All landings are just controlled crashes!
(in reply to Patxipt)
       Post #: 2
RE: Buying Castor - which type? - 3/6/2007 7:05:08 PM
Sport_Pilot
Status: offline
Bakers AA.
(in reply to Motorboy)
       Post #: 3
RE: Buying Castor - which type? - 3/6/2007 7:08:36 PM
Patxipt
Status: offline
I don't have those fancy suppliers like you guys across the pond...
Thnaks guys
Modelling regards,
Francisco
(in reply to Sport_Pilot)
       Post #: 4
RE: Buying Castor - which type? - 3/7/2007 1:53:12 AM
downunder
Status: offline
You should be able to get Castrol M in Europe because Castrol started in England. BTW, the Castrol name comes from CASToR OiL which is what the company started with about 100 years ago.
Medicinal castor isn't recommended because it may have additives in it like sugar, in fact the Merco instructions specifically state not to use medicinal castor. Any castor labelled as AA is fine because that means it's only made by pressing the oil and doesn't have the extra step of chemical extraction which leaves traces of those chemicals that cause the white flakes sometimes seen in certain fuels.
       Post #: 5
RE: Buying Castor - which type? - 3/8/2007 7:07:18 PM
Motorboy
Status: offline
quote:
ORIGINAL: downunder
Never heard about sugar in Medicinal castor, in our land are sugar not added in Medicinal castor. Maybe in other land are sugar added for taste..
Jens Eirik
< Message edited by Motorboy -- 3/8/2007 8:03:56 PM >
Jens Eirik
(in reply to downunder)
       Post #: 6
RE: Buying Castor - which type? - 3/8/2007 7:49:30 PM
wcmorrison
Status: offline
Gee, I wish the medicinal Castor Oil I took as a kid had sugar in it. It didn't and tasted ugh. I guess not one gets dose with that stuff any more. Revealing may age, eh.
Cheers,
Chip
       Post #: 7
RE: Buying Castor - which type? - 3/11/2007 10:15:11 PM
Marcol
Status: offline
quote:
ORIGINAL: Patxipt
Hello all.
Thank you
Don't ask for castor full stop.
Castor oil is bad for humans and also bad for model engines ! Especially 4 strokes. For some reason the older generation of modellers seem reluctant to ditch castor in favour of modern ,clean burning synthetics.
Living in europe, you should be able to get hold of a fuel containing Aerosave fully synthetic oil. Manufactured by the Fuchs oil Co in Germany
This is the fuel you need. The best . http://www.westonuk.co.uk/index_030.htm
I've been using this fuel for 5 years now in everything from an O.S. 10LA to a Laser 240 V Twin. All my engines are spotless inside and out. None of them look like they have been "dipped in toffee".
I don't use any afterun oil. I just run the engine dry at the end of the days flying. The Aerosave oil has the best anti-corrosion properties of any oil. After the winter lay off all my engines are free and not locked solid with castor goo.
       Post #: 8
RE: Buying Castor - which type? - 3/17/2007 6:30:31 PM
Flyer95
Status: online
quote:
ORIGINAL: Patxipt
Thnaks guys
Pharmacy castor is usually very expensive atleast it is here and not needed for our model engines.
All you need is first pressing castor oil without any additives, maybe second pressing also is good enough. Not so hard to tell the quality, just look in the oil buttle and if it is clean yellowish or colorless then it is good. I use a first pressing castor oil that comes from India but maybe castor oil is also locally made in your country? I mix this castor oil with Aerosave synthetic oil in 50/50 ratio. There is no need to run any engine dry or using after run oil, simply not needed and not worth the extra hassle.
Marcol,
I dont understand what is wrong with a castor/syntetic blend? Many very well known glow engine manufacturer still recommend a castor/syntetic blend to be used.
       Post #: 9
RE: Buying Castor - which type? - 3/17/2007 8:01:14 PM
Patxipt
Status: offline
Besides pharmacy castor costing big bucks (cheaper on the drugstore) lubricating castor (first press) is only available to retailers or companies.
My flight instructor has access to this castor and made me a batch of fuel. It seems he's the man to talk to when buying castor :P
Thank you all for your inputs
Modelling regards,
Francisco
(in reply to Flyer95)
       Post #: 10
RE: Buying Castor - which type? - 3/18/2007 3:12:46 AM
jetpack
Status: offline
$60 for a half-gallon FAI fuel?
       Post #: 11
RE: Buying Castor - which type? - 3/18/2007 6:05:30 PM
Marcol
Status: offline
quote:
ORIGINAL: jetpack
I pay £17.00 / Gallon for Prosynth 10% nitro. That's a proper gallon not a U.S. gallon. I think that works out at about $30 an imperial gallon.
I didn't say it was cheap , all I said was it's the best.
(in reply to jetpack)
       Post #: 12
RE: Buying Castor - which type? - 3/18/2007 6:16:40 PM
jetpack
Status: offline
That's a better figure, I just pulled up that link and seen the cost...I think I was reading the table incorrectly. I also didnt't notice the UK price was for (4) 1/2 Gal.
< Message edited by jetpack -- 3/18/2007 6:19:39 PM >
(in reply to Marcol)
       Post #: 13
RE: Buying Castor - which type? - 3/18/2007 6:38:14 PM
JPMacG
Status: offline
Where in the U.S. can we buy Bakers AA castor other than through Sig, S&W, and other fuel suppliers? I did an internet search and found nothing. Baking supply houses maybe?
       Post #: 14
RE: Buying Castor - which type? - 3/18/2007 6:42:26 PM
jetpack
Status: offline
I think there was another thread that I read where someone was getting thiers from a local bakery.
(in reply to JPMacG)
       Post #: 15
RE: Buying Castor - which type? - 3/20/2007 3:20:36 AM
gkamysz
Status: offline
I use castor from motorcycle shops. Klotz Benol or Maxima Castor 927. I've used Sig castor but in diesel fuel it didn't blend well, but the others did.
Greg
