Steering dampener
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Motorcycles >> Steering dampener Page: [1]
Login
Steering dampener - 3/6/2007 6:19:54 PM
944gtr
Status: offline
Hello and thank you for any help,
I purchased a used Thunder Tiger FM-1e and have been tuning it to run it this spring. The former owner had trouble with the steering. After researching the topic, I purchased the Thunder Tiger steering dampener. My questions are three fold.
1) The dampener is not meant to replace the steering linkage, is it?
2) Has anyone had success using this hardware?
3) How did you mount it?
My current thought is to use a suggestion I found on the internet that uses a servo horn and two light weight springs as a replacement for the original poly tube setup.
       Post #: 1
RE: Steering dampener - 3/6/2007 6:54:49 PM
whitham69
Status: offline
the TT damper is a replacement for the fuel tube & rods. a spring should be inside and outside the damper,along with some light oil.
use some ball joints to connect the servo horn to headset.
I raced with this system for a while with np. but i moved to the NF rod and double spring for easyer set up. the damper works fine but if you have the alloy one use two grub scews and some thread lock.
Revese the steering as well so turning the stick right will turn the wheel left. these bike counter steer.
(in reply to 944gtr)
       Post #: 2
RE: Steering dampener - 3/6/2007 9:40:42 PM
944gtr
Status: offline
Thank you Whitham69 for the info.
Sincerely,
944gtr
(in reply to whitham69)
       Post #: 3
RE: Steering dampener - 6/10/2007 6:22:40 AM
Custnam
Status: offline
I have the electric Ducati and want a better steering set up as well. Can you tell me where you got your dampener? And once you got it set up how much improvement was it from the fuel tubing. Im running that now and have gotten pretty good with it. But I just installed a 19x2 motor and have a little head shake now coming out iof turns if I throttle up too soon. Ive heard that a dampener will help this. Also I want to swap out the tires, the triangle fron tire is pretty funky. I found some PMT 100's which are mediums. Is this a good all around tires for parking lot playin? Thanks
_____________________________
He loved us enough to Die for US, Love HIM enough to live for HIM
       Post #: 4
RE: Steering dampener - 6/10/2007 1:58:30 PM
whitham69
Status: offline
100 will be fine for car park bashing.
check here damper or for nf style steering set up http://2wheelhobbies.com/
(in reply to Custnam)
       Post #: 5
RE: Steering dampener - 6/10/2007 10:45:27 PM
Custnam
Status: offline
Thanks, Is this the damper your referring to? http://2wheelhobbies.com/product_info.php?cPath=23_34&products_id=244
And are there dampers that are electric and nitro specific? Or is the set up he same on both? I have the elec. Thanks again
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.546RCU1
