RE: How to cut perfect fit fuse truss?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: How to cut perfect fit fuse truss?
Page: <<   < prev  1 [2]
Login
RE: How to cut perfect fit fuse truss? - 3/8/2007 4:21:43 PM
EJB
Status: offline
Hey Wayne,
show em' the BBW that's going to be at Toledo.
_____________________________
"Ward, weren't you a little hard on the Beaver last night?"
(in reply to BBW Walt)
       Post #: 26
RE: How to cut perfect fit fuse truss? - 3/8/2007 4:40:15 PM
wgeffon
Status: offline
This old thing??
Click to see fullsize image.
Click for fullsize
Click for fullsize
Wayne
(in reply to EJB)
       Post #: 27
RE: How to cut perfect fit fuse truss? - 3/8/2007 5:11:32 PM
zzw26n
Status: offline
I have uncontrolled body functions when ever I see that Plane. Wonder why?
EJB, as far as the Beaver is concerned, you can't hurt it.
regards, Ward
(in reply to wgeffon)
       Post #: 28
RE: How to cut perfect fit fuse truss? - 3/17/2007 11:48:24 PM
old git
Status: offline
quote:
ORIGINAL: BBW Walt
Make yourself a marking jig, no better way. I make the cuts on a 4 inch table saw. No sanding and the results makes perfect angles...Handing out some trade secrets guys..Hope this helps, Walt
As an engineering lecturer for over 30yrs and a modeller since round about 1947 I didn't expect to learn about building a simple box fuselage. I have a fully kitted out FULL size woodwork shop and I also bought a number of small power tools sold for use by builders of dolls houses. I bought a miniature rise and fall/tilt circular saw - 2"dia blade, a belt sander - 1" belt 3" long, an electric plane that uses a pencil sharpener - helical blade and a number of other miniature "Bohler" tools from Germany, I guess I was a proper know it all.
Suddenly you give me the advice that I have been needing for most of a lifetime. I have used that technique when drawing a mitre etc. but on a drawing board. Thank you very much! I really do hate finding from someone else what I should have already known.
In case you haven't guessed, I will use that technique in future.
old git - - - - - - - aka John L.
       Post #: 29
RE: How to cut perfect fit fuse truss? - 12/12/2007 4:46:42 AM
Leardriver
Status: offline
Hey Walt,
I just finished building the truss for my 40% 300...your little gizmo is vey clever and works like a charm! Thanks...I blew through those fuse sides very quickly. I do have the little Harbor Freight table saw (and mini chop saw by the way...it rocks also) but I find that using the sanding disc that is incorporated into the side of my Dremel Scroll saw works very well and is super fast. I would say 3 minutes on average from marking to ready to glue! Outstanding! Thanks Again.
PaulP
"Leardriver"
(in reply to old git)
       Post #: 30
RE: How to cut perfect fit fuse truss? - 12/12/2007 10:18:34 PM
as722
Status: offline
Yes Walt if it wasn't because of your gizmo it would have taken Paul four days per truss instead of two.
Albert
Carden Aircraft
(in reply to Leardriver)
       Post #: 31
RE: How to cut perfect fit fuse truss? - 12/13/2007 6:33:53 AM
Leardriver
Status: offline
Yo Albert..message waiting for you on SUAF...
Paul
(in reply to as722)
       Post #: 32
RE: How to cut perfect fit fuse truss? - 12/13/2007 2:11:11 PM
kregan
Status: offline
I cut by hand/eye with a razor saw. Then use a sander I
built to make it just right. I feel more in touch with the
aircraft when I use hand tools.
But what do I know, I'm just a Hammerhead!
Click for fullsize
Kelly
Flying at FSA? We got your B.A.C.C. !!!
       Post #: 33
RE: How to cut perfect fit fuse truss? - 12/15/2007 7:19:04 PM
Buzzed
Status: offline
quote:
ORIGINAL: kregan
Do you use an automatic feed on the X and Y axis on your milling machine or do you do this by hand also. Buzzzz
Buzzed
(in reply to kregan)
       Post #: 34
RE: How to cut perfect fit fuse truss? - 12/15/2007 7:36:59 PM
kregan
Status: offline
My mills are actually drill/mills not a true mill with a fixed head.
Everything is hand operated. I wish I had a little CNC mill to
play with.
quote:
ORIGINAL: Buzzed
Kelly
(in reply to Buzzed)
       Post #: 35
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.906RCU1
