Ed Cregger
GA, USA Status: offline
If one uses ball links on the aileron linkage, and the wing is near the datum line of the model, no differential is needed. The whole idea is to get the wing to "fly" through the natural roll of the model, instead of skidding. Once upon a time (as many of you will remember) our servos used a square output peg, instead of being fitted with fine splines. There was no electronic neutral adjust, no exponential, no total travel control (volume) and you had to set up your model to fly through the maneuvers with only your ability to "see the angles" needed in the servo's output wheels. Honest! I laugh when I hear people bellyaching about having to set up radios today. Being an old troll, I still do as much trimming as I can mechanically. Then, if needed, I'll tweak it up with the electronics on the Tx. Ed Cregger
_____________________________
Artisan "Flying models since the Fifties - I'll get the hang of this yet!!!"
