skreamer
AZ, USA Status: offline
Skypilotone, I dont think that would be possible as the carb will probably make extensions verry thin. Also the rear case is cracked through under the cylinder. Jrjohn, hard pack dirt. I bought a used wood 22x8 msc that met its end on this flight. Thankfully it was not the carbon fiber that is due in on monday. $46 whew! Yes at this price I can afford to buy another which my WIFE pointed out as she told me to quit whining about my broke motor and plane. 2 for 1 is always a good deal. Bosshov, crank looks good checked with dial indicator side and front but I'm no machinist. Skypilotone, Distributor Ha Ha hahahahahahahahahahahahh. Sent message to Peak about back plate cylinder, gasket, muffler, and mount (have not had one donated yet?). I will keep you guys updated on what i hear back from them. Always happy to be the guinnypig and take one for the team and all that. I disassembled back plate, mount,carb, and cylinder in about 15 minutes. These engines are so simple. If I can get parts should only take a few minutes to reassemble. By the way the cylinder looks excellent and has no visible wear. Engine internals were very clean and tight.
< Message edited by skreamer -- 3/10/2007 3:13:20 AM >
