RE: Let's try again DL-50
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
RCGF 26CC Gas Engine
Seller:  Furyflyer2
Details:   $192.99   |  11/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Let's try again DL-50
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Let's try again DL-50 - 3/19/2007 6:39 AM
Antique
Score: 105
Last Login: 11/7/2009
Status: offline
The high end problems wouldn't be conncted to the ring not seated, this one was perfect from the start...
RTK, I will measure it timorrow, I want to look inside it again anyway...
Hide Signatures
(in reply to RTK)
       Post #: 201
RE: Let's try again DL-50 - 3/19/2007 6:52 AM
bcchi
Score: 100
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: frieshoo
I'm using a 6v Nicad pack.... 1400mah... I thought the Rcxl ignition was rated at 4.8, and 6???
I have tested the RCEXL with 6 volts ,I do not believe 6 volts would hurt it .But it does increase the battery drain about 150 MA and the power transister runs pretty hot.I does not need 6 volts ,spark is plenty hot with 4.8 volts. I just received a new order of the CHRCEXL igns and they no longer have 6 volts on the case.I have been flying one on one LYPO cell seems to work out fine. Hall sensor will quite before battery gets low enough to hurt it.Engine will just go into a high speed miss ,this is time to land .Engine will Idle OK.
BCCHI
Hide Signatures
(in reply to frieshoo)
       Post #: 202
RE: Let's try again DL-50 - 3/19/2007 12:52 PM
Bosshossv8
Score: 100
Last Login: 10/16/2009
Status: offline
WOW.....you can run this ignition on 1 cell?? 3.7v??? If that gets tested and is OK'd by the ignition maker...that would be HUGE!!!
2 more 0zs gone.....I just wonder will the spark heat suffer??
But how cool would that be.....1 TP730 prolite cell................I am running tp1320 2s and it doesn't need that capacity.....
_____________________________
"Are you brave enough to milk a Yak?"
Hide Signatures
(in reply to bcchi)
       Post #: 203
RE: Let's try again DL-50 - 3/19/2007 12:55 PM
PlaneKrazee
Score: 185
Last Login: 11/4/2009
Status: offline
Boss,
How much time are you getting from the 1320 pack?
KB1DTB
AMA11123
Hide Signatures
(in reply to Bosshossv8)
       Post #: 204
RE: Let's try again DL-50 - 3/19/2007 1:01 PM
Bosshossv8
Score: 100
Status: offline
Couldn;t tell you a complete discharge. But after five hard flights about 480mah was put back in the pack.
Hide Signatures
(in reply to PlaneKrazee)
       Post #: 205
RE: Let's try again DL-50 - 3/19/2007 2:35 PM
nmking09
Score: 105
Last Login: 11/6/2009
Status: offline
I managed about two hours idle time with a 400mah battery.
Don't fly what you can't afford to buy two of !!!
Hide Signatures
       Post #: 206
RE: Let's try again DL-50 - 3/19/2007 3:13 PM
frieshoo
Score: 105
Last Login: 11/5/2009
Status: offline
BC,
Thanks for your help the other day.
I had about 20 flights on the ignition running 6v, so I don't think 6v would fry it....
However, I left the ignition switch on all night by accident... I peaked the battery at the field, and DIDN't check the voltage... Fired up the DL50, did a quick range check (I had just installed new aileron servos), and took off... about half way through my flight (8 minutes), the engine just quit (I was at about half throttle).. (like I turned the switch off)...
Dead stick landing...
First thing I thought was the ignition battery was hurt when I left the switch on... So I checked the battery with a load check, under a .5 load the battery read 6.88 volts... it read 7.15 with no load...
I think that voltage is to high... just a guess..
Dennis
Dennis Anders AMA 625293
Lowgap Flying Club Lowgap, North Carolina
Hide Signatures
(in reply to nmking09)
       Post #: 207
RE: Let's try again DL-50 - 3/19/2007 4:26 PM
SERCE
Score: 100
Last Login: 8/15/2009
Status: offline
Could someone give me the dim from one of the back mount ears to the thrust washer ?
In inches please !
Ron
Southeast R/C Engines
Hide Signatures
       Post #: 208
RE: Let's try again DL-50 - 3/19/2007 4:39 PM
nmking09
Score: 105
Status: offline
Use onlineconversions.com 17cm = 5.509324792e-18 parsec = 6.692913386 inches and yes I did measure to 10 sig figs.
Hide Signatures
(in reply to SERCE)
       Post #: 209
RE: Let's try again DL-50 - 3/19/2007 6:02 PM
hvac
Score: 100
Last Login: 7/12/2008
Status: offline
just found out that Scott at dawghouse rc is going to be selling and supporting the DL 50 as well as the 3mm motor at his new shop in brownsburg, in. so all you guys needing support on your DL50's now have a usa shop. he will have the DL50 and the 3mm at his booth in Toledo.
Hide Signatures
       Post #: 210
RE: Let's try again DL-50 - 3/19/2007 6:06 PM
jrjohn
Score: 100
Status: offline
Wow, that boy is going to sell some motors! The 3mm is beautiful!
John
If we all think the same, only one of us is necessary
Hide Signatures
(in reply to hvac)
       Post #: 211
RE: Let's try again DL-50 - 3/19/2007 6:24 PM
bubbagates
Score: 115
Status: offline
This is getting better and better all the time, now we have a US distributor...COOL
Bill James
-IMAC Northeast Regional Director
Hide Signatures
(in reply to jrjohn)
       Post #: 212
RE: Let's try again DL-50 - 3/19/2007 6:45 PM
Mitsu1
Score: 100
Status: offline
Yes, but what will Scott at Dawghouse's price be for the DL-50? I bet a million bucks it will be noticeably higher than $370 delivered! He sells the 3M for $420 plus shipping.
Hide Signatures
(in reply to bubbagates)
       Post #: 213
RE: Let's try again DL-50 - 3/19/2007 6:48 PM
jrjohn
Score: 100
Status: offline
quote:
ORIGINAL: Mitsu1
I'm guessing cheaper than the 3MM. seriously...... Looking at both engines, I'd say the 3mm is better quality. The muffler on the 3MM is like nothing you have seen before. Weighs about 5.2 oz. The DL muffler is pretty rough looking but weighs about 1 oz less.
John
< Message edited by jrjohn -- 3/19/2007 6:51 PM >
Hide Signatures
(in reply to Mitsu1)
       Post #: 214
RE: Let's try again DL-50 - 3/19/2007 6:49 PM
Mitsu1
Score: 100
Status: offline
OOopps, .. Ok, I see he's lowered the price to $390 plus shipping on the 3M. Was $420+ a month ago.
Hide Signatures
       Post #: 215
RE: Let's try again DL-50 - 3/19/2007 6:54 PM
jrjohn
Score: 100
Status: offline
quote:
ORIGINAL: Mitsu1
Wait till you see the new digital programable servo's coming out. They will nock another couple hundred bucks off your plane.
John
Hide Signatures
       Post #: 216
RE: Let's try again DL-50 - 3/19/2007 6:56 PM
frieshoo
Score: 105
Status: offline
hvac,
That is excellent news. Several guys at my club are very interested in the new 50's (DL and 3MM)... So to have a distributer in the US is a big plus.... I would pay more (> $370) to someone in the US.
Hide Signatures
       Post #: 217
RE: Let's try again DL-50 - 3/19/2007 7:26 PM
Mitsu1
Score: 100
Status: offline
Well, you don't need to be telling everyone that .. out in an open forum. Y'all gonnna run the price of the DL-50 right up just below the DA-50! . ... You do know what happens when a supplier realizes he has a strong demand, .. don't you?
< Message edited by Mitsu1 -- 3/19/2007 7:28 PM >
Hide Signatures
       Post #: 218
RE: Let's try again DL-50 - 3/19/2007 7:33 PM
Mitsu1
Score: 100
Status: offline
Also, we better hope this Scott doesn't get an exclusive on the DL-50 ... then we're guaranteed to be paying $470 for it!
Hide Signatures
       Post #: 219
RE: Let's try again DL-50 - 3/19/2007 7:41 PM
frieshoo
Score: 105
Status: offline
Peakmodel is in New Zealand, and Mirc is in Hong Kong. You can order from them even if someone get's exclusive rights in the USA. FWIW, Mirc emailed me and said they will be offering the DL50 with different muffler options for $359 shipped to Virginia.
The DL manufacture will not raise the price, because they could lose business to the guy next door....
< Message edited by frieshoo -- 3/19/2007 7:46 PM >
Hide Signatures
       Post #: 220
RE: Let's try again DL-50 - 3/19/2007 10:44 PM
CrateCruncher
Score: 100
Status: offline
Ssssssssssssss! Anyone feel like plotting thrust curves for a range of common props: Thrust vs. RPM for different props? Now that we know it runs lets start tuning it!
"Never be seen with an ugly airplane."
Hide Signatures
       Post #: 221
RE: Let's try again DL-50 - 3/19/2007 10:48 PM
bahamadude
Score: 100
Status: offline
quote:
ORIGINAL: frieshoo
Do they have a website ?
MIRC sounds like file sharing program hehe
Hide Signatures
       Post #: 222
RE: Let's try again DL-50 - 3/20/2007 1:19 AM
nmking09
Score: 105
Status: offline
Just got e-mail from Steven (the guy I bought my DL from on e-bay, sylvian1975). He told me that he is going to list replacement parts for the DL on ebay in the next day or two. He is a very trustworthy person. Do not hesitate to buy from him.
He has been nothing but helpful in replacing my ignition, and in answering the questions I have had.
Hide Signatures
(in reply to bahamadude)
       Post #: 223
RE: Let's try again DL-50 - 3/20/2007 3:31 AM
vfalcon7
Score: 100
Status: offline
Hello, Can anyone tell me where to get one of these engines? I have looked on Ebay and I can not find peak models website. Thanks for any help.
Hide Signatures
       Post #: 224
RE: Let's try again DL-50 - 3/20/2007 4:27 AM
nmking09
Score: 105
Status: offline
Peakmodel.com
Or in a few days
sylvian1975 will have them on e-bay.
Hide Signatures
(in reply to vfalcon7)
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.156RCU1
