WHat is the best tire for FUSION for more control & not spin a lot??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Schumacher R/C Superstore Support >> WHat is the best tire for FUSION for more control & not spin a lot??
Page: [1]
Login
WHat is the best tire for FUSION for more control & not... - 3/9/2007 4:30:16 AM
Harvz
Status: online
WHat is the best tire for FUSION for more control & not spin a lot in sppeding in straight line?? And also, I need any tips that will make more control besides tires.
       Post #: 1
RE: WHat is the best tire for FUSION for more control ... - 3/9/2007 4:59:26 AM
Schumacher RC Superstore
Status: offline
Something sticky like: http://www.schumacher-rc.com/product_info.php/cPath/93_65/products_id/704
There are other compounds as well. Check out the list: http://www.schumacher-rc.com/index.php/cPath/93_65
Have fun!
_____________________________
Schumacher-rc.com | HavocRc.com | RascalRc.com
(in reply to Harvz)
       Post #: 2
RE: WHat is the best tire for FUSION for more control ... - 3/14/2007 1:24:04 PM
nitrohead5300
Status: offline
RC Superstore are the tires pictured foams??
(in reply to Schumacher RC Superstore)
       Post #: 3
RE: WHat is the best tire for FUSION for more control ... - 3/30/2007 3:37:04 PM
Status: offline
Those are rubber.
(in reply to nitrohead5300)
       Post #: 4
RE: WHat is the best tire for FUSION for more control ... - 3/30/2007 5:40:17 PM
ProRCRacer88
Status: offline
rubber tires are as good as driving on rims for the fusions. Foams are the way to go but I am able to still spin my car out with 1/10th foams on it, and i dont think my engine is even tuned for max output either..
-Wolf Fusion, Kyosho ST-RR
       Post #: 5
RE: WHat is the best tire for FUSION for more control ... - 3/30/2007 5:42:53 PM
Status: offline
On a track foams are the best, for street racing the rubber tires work great. Much more traction than on just rims.
If Schumacher sold foam tires I would be selling them, but they do not offer foam tires any longer so I dont have the option.
(in reply to ProRCRacer88)
       Post #: 6
RE: WHat is the best tire for FUSION for more control ... - 3/30/2007 6:43:16 PM
nitrohead5300
Status: offline
quote:
ORIGINAL: ProRCRacer88
.....................Calandra Racing sells 35mm wide rear tires that are alot wider than your typical 1/10 foam tire you may want to try some of them out . They were my first upgrade when I got my fusion and they really helped I got alot more traction with them. Another option is to get some Wolfpack Radicals tire adapters that will let you put 1/8 scale foams on your fusion contact Wolfpack Radicals for more info.And here is a link for Calandra Racing http://www.teamcrc.com/crc/
< Message edited by nitrohead5300 -- 3/30/2007 6:49:16 PM >
       Post #: 7
RE: WHat is the best tire for FUSION for more control ... - 3/31/2007 2:09:49 AM
ProRCRacer88
Status: offline
nitro i have one with the wolf conversion chassis and one thats stock.
[image] [/image]
remember?
       Post #: 8
RE: WHat is the best tire for FUSION for more control ... - 3/31/2007 2:11:31 AM
ProRCRacer88
Status: offline
thats an old pic, i finished the car back in january, and I have serpent wide tires in the rear.
       Post #: 9
RE: WHat is the best tire for FUSION for more control ... - 3/31/2007 2:15:33 AM
ProRCRacer88
Status: offline
RC Superstore, rubber tires dont provide nearly any traction for the fusion, they make good drift tires, other than that, braking, cornering, and acceleration will be very off with these limited traction tires. Foams offer much better traction in all these areas. In my opinion, rubber tires are never the way to go for nitro rc's, i see them as only being good for electric cars.
       Post #: 10
RE: WHat is the best tire for FUSION for more control ... - 4/1/2007 1:46:48 AM
nitrohead5300
Status: offline
ProRCRacer whats your verdict?? Do you like your Wolfpack Conversion chassis??
       Post #: 11
RE: WHat is the best tire for FUSION for more control ... - 5/22/2007 4:08:00 PM
Pillbots
Status: offline
Thats Vortex21 Nitrohead
Anyway, back on the topic. Foams tires can be very good, at a decent price along as where you are driving your car is fairly clean. The best rubber tires can aparrently have more grip than 35 sh foam tires but they are much more expensive.
< Message edited by Pillbots -- 5/22/2007 4:12:18 PM >
Serpent 960 ''08
Schumacher fusion
       Post #: 12
RE: WHat is the best tire for FUSION for more control ... - 5/22/2007 4:27:46 PM
bajaaddict
Status: offline
foam, foam and more foam. just buy plenty. It looks like the schumacher rc superstore finally got some foams in. dont I need the u2581 rear r12 hubs to run 30mm rear wheels on the fusion?
(in reply to Pillbots)
       Post #: 13
RE: WHat is the best tire for FUSION for more control ... - 5/22/2007 4:35:20 PM
Pillbots
Status: offline
Yeah, you gotta get that part to run 30mm's at the rear.
Serpent 960 ''08
Schumacher fusion
(in reply to bajaaddict)
       Post #: 14
RE: WHat is the best tire for FUSION for more control ... - 5/25/2007 12:34:55 PM
nitrohead5300
Status: offline
Try the Calandra Racing Concept rear foams they are 35mm wide especially if you have a big block or modified motor they will give you more grip.
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
