mando
IL, USA Status: offline
Well........The Zlin flies I've set it up with the recommended throws, and am glad that after the range check at the field and right before the maiden flight, that I set dual rates at -65%! Very responsive this one is! All the first flight trim required was some down on the elevator, and some left aleron. Wants to pull hard left on take off. Got some take offs and landings in to get past first flight gitters. Gonna have to do somethig about the landing gear though. This plane lands like a feather and the landing gear still won't hold it's shape. The metal is too soft with absolutely no memory! Also when I got back to my shop, I unloaded the plane and set it on a work table and the plate that holds the gear on the plane let go and colapsed on it's belly. WTH, come to find out that the hot melt that was used on the inside of the plane had gotten soft and just let go. So......Scraped all that off, got epoxy and glass filler curing now, and am shopping for some worthy landing gear. The Saito .72 has more than plenty umph for this plane!! Maybe too much, but I like it that way I can see some good manuvers with this plane. Mando..........
_____________________________
You can't win if you don't enter
