RE: Zlin Z-50 recieved
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: Zlin Z-50 recieved
Page: <<   < prev  1 2 3 [4]
Login
RE: Zlin Z-50 recieved - 12/12/2007 9:48:45 PM
Speedie500
Status: offline
Hi Guys,
I've been asking around about removing the silver paint from the canopy and 1 of my friends, who is involved with cars & trains, suggested brake fluid. The car bodies are made from Lexan, I don't know what the train bodies are made from, but neither are affected by the brake fluid.
When I find my roundtooit I will try this on the Zlin's canopy.
_____________________________
Speedie
Take off is optional, landing is mandatory.
(in reply to bumpman)
       Post #: 76
RE: Zlin Z-50 recieved - 12/12/2007 10:15:48 PM
bumpman
Status: offline
I don't know what is on these silver painted canopys,but I have tried lacquer thinner and paint remover,neither will touch it."I don't beleive it myself".I have some brake fluid in the basement,I will try that tomorrow.I also tried spraying clear inside thinking maybe it was sand blasted,no luck there either.ALSO no response from NITRO either ! It seems to be a real crap shoot dealing with these people.They are a one shot store,if you get it "right" in the box,its a good deal,but if there is a problem, your stuck !
(in reply to Speedie500)
       Post #: 77
RE: Zlin Z-50 recieved - 12/12/2007 10:55:26 PM
Speedie500
Status: offline
Let us know how you do with the brake fluid, bumpman
Speedie
       Post #: 78
RE: Zlin Z-50 recieved - 12/18/2007 2:37:28 AM
bumpman
Status: offline
Brake fluid did no good,I have been messing with this so much the canopy is now distorted.Very frustrating ! Going to try Nitro again.
       Post #: 79
RE: Zlin Z-50 recieved - 12/18/2007 3:58:05 AM
flyguy506
Status: offline
Here's my Zlin. I rebuilt or replaced or modified the cowling, landing gear, tail struts and moved all the equipment to the CG area. The ailerons were warped so some straightening was in order. The plane flew straight but was a little nose heavy. My son flew it on the second flight and made a sharp turn on the ground and the left wheel hub broke. My modified wide landing gear not only held up really good but prevented the plane from hitting a tip! I replaced the wheels with the very durable dubro which were grey and matched the color scheme. I have moved the battery from under the gas tank to behind the gas tank resulting in the CG about a 1/4 inch back from the published CG. I have not had a chance to fly it but will give a complete report when done. This has been the most difficult ARF because of the many modifications and replacement of parts.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 80
RE: Zlin Z-50 recieved - 12/19/2007 8:51:42 PM
Speedie500
Status: offline
flyguy:That's just plain wrong, you got a clear canopy.
Bumpman: Sorry to hear about your deformatey. Good luck with Nitro.
Speedie
(in reply to flyguy506)
       Post #: 81
RE: Zlin Z-50 recieved - 12/20/2007 12:40:00 AM
flyguy506
Status: offline
bumpman, sorry you didn't get a clear canopy. If you have access to the November 2007 issue of Model Aviation( the AMA monthly magazine), they have a detailed article on making your own canopy.
flyguy
       Post #: 82
RE: Zlin Z-50 recieved - 12/28/2007 2:59:50 AM
bumpman
Status: offline
Here's the latest on the Zlin clear canopy, John came through for me. I received one Christmas eve.from Nitro,So now I am good to go !
       Post #: 83
RE: Zlin Z-50 recieved - 2/22/2008 8:50:08 AM
goph
Status: offline
how is the progres on everybodys zlin . my be like me no time to even look at it.
hope to be in the air in the next few weeks all going well.
       Post #: 84
RE: Zlin Z-50 recieved - 2/22/2008 11:41:24 PM
spinnerman
Status: offline
Can U tell me want the CG is????
Fly Hard or Go Home
(in reply to goph)
       Post #: 85
RE: Zlin Z-50 recieved - 2/27/2008 3:31:31 AM
mando
Status: offline
The manual ( if you can call it that ) calls for 80mm or 3.1 inches. I've got mine at 3 3/16" and it's a little touchy at that. I think I'll move it forward a little this spring.
Mando........
You can't win if you don't enter
(in reply to spinnerman)
       Post #: 86
RE: Zlin Z-50 recieved - 2/27/2008 7:18:24 AM
spinnerman
Status: offline
Thanks, I asked the owner of Duncan's R/C here in Phoenix, Arizona
what he thought. I used a 480-500 class outrunner motor w/ a 9x6 prop and a 2200mAp Lipo.
He told me to set the CG at 3 1/2" that worked out GREAT. Flow just Great until the speed control melted. Only had to add 14grams to the nose. I had the battery as far forward as I could get it.
Thanks for the reply Mando
Fly Hard or Go Home
(in reply to mando)
       Post #: 87
RE: Zlin Z-50 recieved - 4/29/2008 2:22:38 PM
PA BEN
Status: offline
Anyone have info on the 120 size Zlin Z50?
       Post #: 88
RE: Zlin Z-50 recieved - 4/29/2008 6:43:10 PM
spinnerman
Status: offline
Here are a couple site I have found
http://www.raidentech.com/fofw190bubi1.html
Fly Hard or Go Home
(in reply to PA BEN)
       Post #: 89
RE: Zlin Z-50 recieved - 4/29/2008 11:54:46 PM
PA BEN
