Rc10gt Engine.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Rc10gt Engine.
Page: [1] 2 3   next >   >>
Login
Rc10gt Engine. - 3/12/2007 12:37:51 AM
kyle9013
Status: offline
Im looking for a new Engine for my Rc10gt.
Ive been hearing OS .18 CVRX is a good one.
True?
any other ideas?
if i got a new engine would i need to do any mods?
or do i need to get anything so that the engine fits?
       Post #: 1
RE: Rc10gt Engine. - 3/12/2007 12:40:36 AM
ICrashThings
Status: offline
If you are getting that .18 I would highly suggest you get RRP steel transmission gears. It just makes life easier. Just remember to clean out your transmission after every gallon of fuel and you are golden.
_____________________________
lol $300 Radio? Me controlling it? rofl...
(in reply to kyle9013)
       Post #: 2
RE: Rc10gt Engine. - 3/12/2007 12:59:08 AM
kyle9013
Status: offline
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGGP7&P=7
that one will drop in correct?
and where do i get the gears at? and is that all i need?
(in reply to ICrashThings)
       Post #: 3
RE: Rc10gt Engine. - 3/12/2007 1:02:59 AM
ICrashThings
Status: offline
Well, of course u are going to need to cut that shaft, then find a crutch nut, flywheel, clutch shoes, etc...
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLL23&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPZ87&P=7
Gears^
       Post #: 4
RE: Rc10gt Engine. - 3/12/2007 1:14:48 AM
kyle9013
Status: offline
Well. is there other motor that you would recommend?
im new to nitro, and i got this car in a trade,
just having problems with it.
       Post #: 5
RE: Rc10gt Engine. - 3/12/2007 1:38:07 AM
ICrashThings
Status: offline
Usually when people get a Nitro car in a trade or by it from someone else you end up getting their problems. Especially when u are new to it(as goes for anything, old cars, houses, other hobbies), Although there will be people who will say "But ICrashThings! I got mine in a trade from someone and NEVER HAD A PROBLEM WITH IT!" which happens, but not all the time. Usually if you are new to it, by it new so YOU can play with it first and not get sloppy seconds. But if I were you, I would read up on the GT's manual(if u even got one) and take it apart. This way you learn how it works, and where the pieces go. Just clean everything, might need to refill the shock lube, grease the transmission,...etc...
But back on topic. OS engines are great. I never had a problem with mine and they come dialed from the box. All you need to do is break the engine in with the companies break in proceders and u will be good.
       Post #: 6
RE: Rc10gt Engine. - 3/12/2007 2:09:36 AM
dannthenitroman
Status: offline
Yeah you need to cut the shaft and get the new clutch setup, with the clutchnut, but yeah RRp gears too, get them from tower.
       Post #: 7
RE: Rc10gt Engine. - 3/12/2007 2:17:17 AM
kyle9013
Status: offline
Alright. do you guys mind helping me find them on tower, so when i do upgrade i know what im getting.
Thanks.
and cutting the shaft is that easy to mess up? or is it pretty basic
(in reply to dannthenitroman)
       Post #: 8
RE: Rc10gt Engine. - 3/12/2007 2:58:10 AM
ICrashThings
Status: offline
quote:
ORIGINAL: kyle9013
Thanks.
Well I posted the links:
quote:
ORIGINAL: ICrashThings
Gears^
And all u need to cut the shaft is a dremel tool with a spinning disc cutter. Its simple actually, put the engine in a sandwich bag and poke through it with the shaft. This way none of the metal shavings get into/on your engine. When you cut it, cut the shaft all the way down until u have about rouchly 4 threads on it. Ifs its too much then cut another off, u want the clutch nut to be on it and right against the fly wheel. To make sure it stays on, you can try to use lock tite on it...a lot of people might disagree with this, but its your choice.
       Post #: 9
RE: Rc10gt Engine. - 3/12/2007 2:59:30 AM
dannthenitroman
Status: offline
VERy basic, you just grind it down untilit works very basic.
Youll find it easy to find the parts just search robinson racing on tower.
       Post #: 10
RE: Rc10gt Engine. - 3/12/2007 3:01:21 AM
kyle9013
Status: offline
Alright. sounds pretty easy. and yeah i thought someone said i needed more stuff. just besides those 2 items.
       Post #: 11
RE: Rc10gt Engine. - 3/12/2007 3:05:30 AM
ICrashThings
Status: offline
quote:
ORIGINAL: kyle9013
Well...If you want to go farther:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAX13&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAX63&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEY79&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD085&P=M
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LX3371&P=7
(should work^)
       Post #: 12
RE: Rc10gt Engine. - 3/12/2007 3:17:52 AM
dannthenitroman
Status: offline
yep thats what you want right there.
       Post #: 13
RE: Rc10gt Engine. - 3/12/2007 5:42:51 AM
kyle9013
Status: offline
Wow. thanks. is that just for that Os. 18 CVRX engine? or can all this be used for others as well?
the only thing that is not available is the Clutch nut.
       Post #: 14
RE: Rc10gt Engine. - 3/12/2007 8:12:53 AM
kyle9013
Status: offline
I know this car is missing some other crap too. isnt there supposed to be Springs on the brake and throttle linkage? just from what ive seen on peoples Rc10gts.
       Post #: 15
RE: Rc10gt Engine. - 3/12/2007 9:59:18 AM
duckedup
Status: offline
quote:
ORIGINAL: kyle9013
Yes..
       Post #: 16
RE: Rc10gt Engine. - 3/12/2007 12:03:37 PM
dannthenitroman
Status: offline
spring on the throttle but on the brake don't. use fuel tube there. its more consistent and heavy feeling.
(in reply to duckedup)
       Post #: 17
RE: Rc10gt Engine. - 3/12/2007 5:40:15 PM
kyle9013
Status: offline
i just ordered one, cause the one that is on there doesnt have a spring and such. i hope there isnt to much missing from the car.
(in reply to <
