rctom
TX, USA Status: offline
quote:
ORIGINAL: Sandy69 Well finally...............for those of us who are mathmatically declined, and live in Canada, 32:1 is 125ml oil to 4 liters of gas.......checked and re-checked, lilkely still wrong, BUT... tied the new extra down to a cinder block (lordy this thing is large) filled the tank..held my breath ignition off, choke closed, throttle open, three flips had fuel to the carb ignition on, choke closed, throttle open, three flips and the engine barked ignition on, choke open, throttle open 1/8, thwo flips and the engine was running...breathed after warm up the idle was 2290 (will undoubtedly adjust down) [)] , top end was 6800 with a MSC 22x8 played with the throttle a bit then shut it down after about 5 minutes............for now I am estatic.....thank you TOM.. Keep ya'll advised. That's what we like, by the book. I keep telling people the 3mm engine is a class act. TF
