RE: New 53cc engine now available
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: New 53cc engine now available Page: <<   < prev  18 19 20 21 [22] 23 24 25 26 27   next >   >>
Login
RE: New 53cc engine now avai... - 5/6/2008 8:28:52 PM
Sandy69
Status: offline
I got mine from NAPA......I chased down a Shell rep and he found it for me, but i had to get NAPA to bring it in from Moncton
(in reply to skyriter)
       Post #: 526
RE: New 53cc engine now avai... - 5/6/2008 10:04:58 PM
Tired Old Man
Status: offline
Yes, the Stihl was in the tested group. If the engine is kept relatively cool and not run lean you're good to go but if you run hot frequently you can easily stick a ring. It was about middle of the road and will generally be fine to use. Funny, but I found out the same thing with one of my engines long before the performance tracked testing was done.
_____________________________
If you can''''t fix it with a hammer, you have an electrical problem.
       Post #: 527
RE: New 53cc engine now avai... - 5/6/2008 11:50:07 PM
skyriter
Status: offline
Is that test data available? Or at least a list of the brands etc. Would be nice to see some of the brands that were on the list. This would help in finding a good oil in Calgary - Canada.
Bruce
(in reply to Tired Old Man)
       Post #: 528
RE: New 53cc engine now avai... - 5/7/2008 12:24:42 AM
Sandy69
Status: offline
I agree, that test info would be great to have...
       Post #: 529
RE: New 53cc engine now ava... - 5/7/2008 12:36:56 AM
Tired Old Man
Status: offline
No, it's not available. It was performed by a privately funded test group.
(in reply to Sandy69)
       Post #: 530
RE: New 53cc engine now ava... - 5/7/2008 10:46:07 PM
RPool
Status: online
My club just adopted the IMAAC sound standards (96db?). I don't own a DB Meter of any kind and would rather not buy one if it is not necessary. I figured many on this forum are in the same position and could share info efficiently. Will I need to buy a cannister to replace my stock muffler? I'm running a 22 x 8 carbon fibre prop and a 23A Vess so there is no prop rip. Here are the club details:
The sound level will be measured over Grass with a maximum sound level of 96 DB using a Radio Shack sound meter set on slow response and using the A scale. Any other meter will need to be calibrated against one of the club meters before it can be used.
The measurement will be made at a distance of 25 feet downwind from the spinner centerline. The meter will be at a height of 24 inches above the ground. The meter will be held parallel to the propeller and 1-2 feet behind the propeller disc in the interest of safety.
Proper and secure restrain of the model must be performed during the test and all spectators must be well behind the model.
       Post #: 531
RE: New 53cc engine now ava... - 5/8/2008 12:06:02 AM
skyriter
Status: offline
"The measurement will be made at a distance of 25 feet downwind from the spinner centerline. The meter will be at a height of 24 inches above the ground. The meter will be held parallel to the propeller and 1-2 feet behind the propeller disc in the interest of safety. "
Just a question... if you are taking the reading from 25 feet behind the plane (spinner) - how does the 1 to 2 feet away from the prop disk and parallel to it fit in?
Bruce
(in reply to RPool)
       Post #: 532
RE: New 53cc engine now ava... - 5/8/2008 4:51:03 AM
rctom
Status: online
It's not 25 feet behind the plane, it's 25 feet away to the side, just slightly behind the plane of the prop. This is all standard IMAC stuff.
TF
       Post #: 533
RE: New 53cc engine now ava... - 5/8/2008 7:43:00 PM
Jake Ruddy
Status: offline
You might get away with a CF prop but that Vess prop won't cut it. Great 3D prop but very loud.
(in reply to rctom)
       Post #: 534
RE: New 53cc engine now ava... - 5/9/2008 12:34:59 AM
TheFoxes
Status: offline
Just have to say Tom -
My 53 is STILL a great engine. After sitting since October, I finally got my Edge out to field today. After wetting the pump diaphragm with fuel and priming the fuel line, it took seven flips to get it to idle. After a 3 minute warm-up is spun the Bunny 22X8 up to 6900, idled down to a impractical airframe shaking speed. Never touched a needle and it flew for 30 minutes today without so much as a hiccup. Thanks for making these things available and working so hard to make them great!
Forrest
(in reply to Jake Ruddy)
       Post #: 535
RE: New 53cc engine now ava... - 5/10/2008 6:19:01 AM
bluemagic98
Status: offline
Mine is in one of the first Hondas and she spun up this season with a roar. However I did get a hickup not sure what is causing it any Ideas?
I get this plane in a inverted flat and I get the sticks mashed over to the right and full down elevator and full power. If I get into this from a virtical climb it is a sweet thing to see. The plane will just about spin in its own space and almost hover. Im waiting for the new reed blocks to come out to see if the added horse power will hold it in place. I also feel a prop change is in order I have a Vess on it now and Im note so convinced this is the prop for the honda. Any how its off to the field in a few hours no rest for the weary.
Wild Hare 540 Edge-V1/V2 DA-50 JR9303 WH Cap-232 85" Evolution 58 WH Ultimate WH SU-26
(in reply to TheFoxes)
       Post #: 536
RE: New 53cc engine now ava... - 5/15/2008 5:09:09 AM
RPool
Status: online
Here's a quick "new guy" question...3MM 53 starts well, Idles well, will throttle up smoothly. However. if I try to go from idle to full throttle quickly, it will cut out and die. If I catch it quickly enough and back off on the throttle, it'll pick back up and continue running. Too rich? Too lean? First gas engine. I will go downstairs and grab the manual but thought this would be a quicker way to get feedback from experienced users. Thanks for your help =)
(in reply to bluemagic98)
       Post #: 537
RE: New 53cc engine now ava... - 5/15/2008 5:25:25 AM
roboto65
Status: offline
To lean on the low end richen it up a screwdriver blade width does not take much..
It''s a temporary fix unless it works at which point it becomes permanent!!!
(in reply to RPool)
       Post #: 538
RE: New 53cc engine now ava... - 5/15/2008 5:26:10 AM
rctom
Status: online
The low speed circuit is probably a little lean.
(in reply to RPool)
       Post #: 539
RE: New 53cc engine now ava... - 5/15/2008 5:31:20 AM
RPool
Status: online
Wow, you guys are FAST! Thanks!
(in reply to rctom)
