darrolair@yahoo.com
MT, USA Status: online
rctom, I purchased one of these engines last year. When I received it, I ran it on a test stand about 10 ounces of fuel and promply placed it in my plane. Took it to the flying field. Fired it up and picked up the plane. Held it with the nose up, no problems. Tipped the wing and it died. I contacted you and you said to rotate the reed block and carby 180 degrees. The information worked really well. I'm now getting lots of spitting from the carby. After reading nearly every post on this engine, it looks like maybe the reed block could again be the nemesis. Did anyone sent their reed block back to you for examination and if so, what if anything have you seen or detected? Do you have a reed block on hand? I love this engine. Starts so good and lots of power. Thanks, Darrolair
