Airfoils Q40 Vendetta.. helpme???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> QM-40 Racing >> Airfoils Q40 Vendetta.. helpme???
Page: [1]
Login
Airfoils Q40 Vendetta.. helpme??? - 3/12/2007 11:24:55 PM
fabionet31
Status: offline
hi,
i have two fuse of Q40 Vendetta, and i want made a pair of wing,
but i do not know the airfoils. I have only section of wing (see image)
please helpme.
Fabionet31
Italy
Click to see fullsize image.
Click for fullsize
_____________________________
www.pylonracing.it Ufficial Pylon website in Italy
       Post #: 1
RE: Airfoils Q40 Vendetta.. helpme??? - 3/13/2007 6:10:48 PM
oddy
Status: offline
Fabionet.
It depends on which Vendetta your taking about
If it is a Vanbaren´s Vendetta the airfoil is SD6060 I think.
Ifi it is a Larsons Vendetta, there are 2 or 3 versions with different airfoils.
From the image your posting this seems to me as a Naca 66-112 which is the airfoil of a third Vendetta which exists some time ago (Known as Vendetta Matrix) but I cant recall who the designer was.
Hope this helps.
Victor Arreoal
If I say that the Burra is Prieta is because I have the pelos in my hand.
(in reply to fabionet31)
       Post #: 2
RE: Airfoils Q40 Vendetta.. helpme??? - 3/14/2007 12:57:50 AM
B.P.R.
Status: offline
quote:
ORIGINAL: fabionet31
hi,
please helpme.
Fabionet31
Italy
Ciao Fabio ,
Anchio sono in un altro forum di Q40 a cercare il profilo , a quello che mi sembra di aver capito dall'amico Victor Arreoal ci sono piu' edizioni del profilo per il Vendetta .......Niente toglie che se qualcuno sa' qual'è il piu' performante di usarlo.....chiediamo..
ITALIA PYLONRACING
WWW.PYLONRACING.IT
       Post #: 3
RE: Airfoils Q40 Vendetta.. helpme??? - 3/14/2007 1:03:50 AM
B.P.R.
Status: offline
quote:
ORIGINAL: oddy
Fabionet.
Hope this helps.
Victor Arreoal
Ciao Victor
Grazie per l'informazione
Many thanks for the information........................a question : For you which is the best fast airfoil of the 3 Vendetta version??
Ciao and Grazie
ITALIA PYLONRACING
WWW.PYLONRACING.IT
(in reply to oddy)
       Post #: 4
RE: Airfoils Q40 Vendetta.. helpme??? - 3/14/2007 2:49:33 AM
Marco Vergara
Status: offline
FABIO THAT AIRFOIL IS SD6060, VAN VAREN´S VENDETTA OR MISS ASHLEY.
THE FAST Q40 AIRPLANE IS THE AUSTRALIAN POLECAT, IT HAS A MH24 AIRFOIL.
YOU CAN USE THE ITALIAN AIRFOIL SOFTWARE PROFILI TO GET THE AIRFOIL COORDINATES, IF YOU CAN´T SEND ME A MAIL
AND I WILL SEND IT TO YOU.
marina57@prodigy.net.mx
MARCO
(in reply to B.P.R.)
       Post #: 5
RE: Airfoils Q40 Vendetta.. helpme??? - 3/14/2007 5:36:17 AM
daven
Status: offline
The Vendetta holds the current National record in Q40, and has done quite well in the past few nats. I'm still not sure why more racers don't fly them, but they are completely capable of keeping up with the Polecats.
Nothing against the Polecat, I love that plane also. There is just something about how the Vendetta flies that keeps bringing me back.
I've flown all three airfoils, and honestly, can't tell the difference. The newest airfoil that Lyle is using has worked well for me.
Dave Norman
klasskote.com
supertrc.com
(in reply to Marco Vergara)
       Post #: 6
RE: Airfoils Q40 Vendetta.. helpme??? - 3/14/2007 11:30:58 PM
oddy
Status: offline
Just to support Daven´s comment.
Check out the Winners of the last Q40 contest
- 3 Vendettas in the first 10 spots (one of them the one setting the new national record)
- 3 Polecats
- 2 Proud Birds (Larson)
- 1 Proud Bird (Jim Allen)
- 1 GR-7 (BBR)
Click for fullsize
       Post #: 7
RE: Airfoils Q40 Vendetta.. helpme??? - 3/15/2007 12:25:55 AM
B.P.R.
Status: offline
Many thanks Racers for help we ..
My original wing that I have used to build the mould (in agreement with Lyle ,only to begin Q40 in Italy) ( which was in the kit Lile vendetta) , is similar to SD6060(over) but not equal, I do not know that airfoil is exactly ,however thanks to your helps i want tested the SD6060 . (foam cnc to not spend a lot .......)
Exsused for my bad english
Click for fullsize
Click for fullsize
< Message edited by B.P.R. -- 3/15/2007 1:06:06 AM >
ITALIA PYLONRACING
WWW.PYLONRACING.IT
(in reply to oddy)
       Post #: 8
RE: Airfoils Q40 Vendetta.. helpme??? - 3/15/2007 12:57:23 AM
B.P.R.
Status: offline
quote:
ORIGINAL: oddy
- 3 Polecats
- 1 GR-7 (BBR)
I haven't piloted others Q40 models, but the Q40 Vendetta with which i flight (and my friends), fly truly much good !!!!
(The red Vendetta in immage , I had given To Paolo Mucedola (my Pylon's BIG FRIEND) for Phoenix 2007 .......but said to me have broken in landing )
I think that i build a new Vendetta for Paolo M. with airfoil SD6060
Ciao...
Hope we see in Muncie F3D WC
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
ITALIA PYLONRACING
WWW.PYLONRACING.IT
(in reply to oddy)
       Post #: 9
RE: Airfoils Q40 Vendetta.. helpme??? - 3/15/2007 2:07:01 AM
garys
Status: offline
I think the airfoil on Lyle's first Vendetta was an Eppler 374, but I'm not 100% sure.
GS
       Post #: 10
RE: Airfoils Q40 Vendetta.. helpme??? - 3/15/2007 2:17:12 AM
B.P.R.
Status: offline
quote:
ORIGINAL: garys
Thanks for your info......I see in profili 2.0 (italian software)
Ciao Paolo P.
ITALIA PYLONRACING
WWW.PYLONRACING.IT
(in reply to garys)
       Post #: 11
RE: Airfoils Q40 Vendetta.. helpme??? - 3/15/2007 5:00:31 PM
Kevin Matney
Status: offline
Can you send me the .dat file of the airfoil. I have a CNC foam cutter. I would be glad to work some out with you for the file.
Kevin Matney 2 wrongs don't make a right But 2 Wrights make an Airplane
www.Matneymodels.com
       Post #: 12
RE: Airfoils Q40 Vendetta.. helpme??? - 3/15/2007 6:22:48 PM
kane
Status: offline
Just to correct the top ten list
There were:
2 Vendetta's (Larson design) flown by Matias and Scott
1 RVB Ashely (Rusty design) flown by Matt
2 Polecats (Kane/Dechastel design) flown by Craig and Lee
1 LOKI (Kane/Dechastel design) flown by Travis
1 GR7 (Russell/Dechastel design) flown by Randy
1 Proud bird (Allen design) flown by Shadel
2 Proud bird (Larson design) flown by Lyle and Gino
Dan
< Message edited by kane -- 3/15/2007 6:43:28 PM >
Dan Kane
(in reply to Kevin Matney)
       Post #: 13
RE: Airfoils Q40 Vendetta.. helpme??? - 3/15/2007 7:08:58 PM
fabionet31
Status: offline
Kevin Matney, B.P.R. is my big friend, you want a file .dat for SD 6060 ???
(in reply to kane)
