bob27s
OH, USA Status: offline
Hi Terry..... Thanks for writing. Technically ( per the origina 428 racing rules) it is a muffler ... since it is one piece, fixed geometry, not tunable, and is OEM stock with the engine. (the Rossi and MVVS black mufflers are the same type of exhaust system, except those are actually 2-piece units - just in case that comes up) But that aside... If it is a new engine, break it in properly, per instructions - with the jett muffler on it. Again, follow the Jett break-in instructions, and get at least 20 minutes on the engine, on the test stand. You can use a standard cast-type muffler, but you will indeed lose performance. The engine will outperform an OS46, TT46 in this configuration, if you allow the rpm to stay up a bit. We do run the engines with the lite-jett untuned mufflers, but mainly for sport/3D/aerobatic/control line applications where lower rpm and slightly bigger diamter props are what we are after. The 38mm muffler bolt pattern on the SJ-50 will match a Webra .40-.50 or ST 40-50 size engine. You would be better off finding a muffler from one of those engines. The Mag 52 uses the narrower 37mm OS46/TT46 muffler bolt pattern, and will not match up properly. Also worth noting, the old K&B61 had a 38mm bolt spread too. The Jett engine requires a proper balance of backpressure and muffler tank pressure to operate and draw fuel properly. The stock jett-stream, turbo-jett and lite-jett mufflers provides that condition. If you use something like the Mag 52 muffler, this consideration must not be ignored. Id leave the bafflle in place. What type of aircraft are you flying ? If it is a Q-500 aircraft, and you use a "can" muffler, continue to target 17,000 rpm ground peak for the engine. You will want to use something like an APC 9x6, 9x7, or APC 8.5x7.25, 8.75x7, 8.5x7.5 D1 series prop. Continue to launch the engine down 300-400 rpm off of peak. Let me know some more detail, and I can suggest a starting setup Bob
_____________________________
Bob Brassell Jett Engineering - Engine Mfg Support Forum Host
