ZAGI, Do you have to use a Mini or Micro Rx????
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> ZAGI, Do you have to use a Mini or Micro Rx????
Page: [1]
Login
ZAGI, Do you have to use a Mini or Micro Rx???? - 2/14/2003 12:54:48 AM
compaq
Status: offline
ZAGI, Do you have to use a Mini or Micro Rx???? Will a standard size Rx with Mini Servos work????
       Post #: 1
ZAGI, Do you have to use a Mini or Micro Rx???? - 2/14/2003 1:55:08 AM
RedWing
Status: offline
Sure that will work.
It is just a little more weight.
I use a full size Hitec receiver and full size servos.
Just make sure you put the receiver in the foam and not in front of the battery in the tray. The battery on a crash will destroy the receiver.
Bill
_____________________________
R/C flying is not a hobby. It's a calling.
Hey, Watch this....
(in reply to compaq)
       Post #: 2
Zagi - 2/14/2003 1:55:30 AM
planelazy
Status: offline
I have a Hitec Flash Five in mine with Hitec HS81's. Tim.
       Post #: 3
ZAGI, Do you have to use a Mini or Micro Rx???? - 2/14/2003 1:59:06 AM
RedWing
Status: offline
A flash five is what I use.
You can set up some expo and it will help with slow handling.
I also edited my first post. Reread it.
Bill
Hey, Watch this....
       Post #: 4
ZAGI, Do you have to use a Mini or Micro Rx???? - 2/14/2003 2:00:58 AM
compaq
Status: offline
Thanks guys...
One more thing...
In the instructions it shows the Rx being off center to the left... Is this right?
       Post #: 5
ZAGI, Do you have to use a Mini or Micro Rx???? - 2/14/2003 2:04:11 AM
RedWing
Status: offline
That's how my RX is.
I centered the connectors under the tray.
I cut out the tray in that area so I could plug everything in.
Run your antenna wire through the left wing foam out the left side.
I just let the extra hang off the end of the left wing.
Bill
Hey, Watch this....
       Post #: 6
ZAGI, Do you have to use a Mini or Micro Rx???? - 2/14/2003 2:09:41 AM
compaq
Status: offline
I have a Futaba Super 7 Digital Radio... I have never used the "Expo"... What should I be setting the expo up to do? What is the expo for?
       Post #: 7
ZAGI, Do you have to use a Mini or Micro Rx???? - 2/14/2003 3:01:38 AM
RedWing
Status: offline
With expo you can make the movements at the center of the sticks softer. So, when you first start to move your stick, the control surface move less at first. But when you move your stick a lot you still get the full deflection of your control surfaces.
So small movements of the stick don't make your plane jerk around.
I hope that makes some sense.
Bill
Hey, Watch this....
       Post #: 8
ZAGI, Do you have to use a Mini or Micro Rx???? - 2/14/2003 6:03:18 AM
HavingFun2002
Status: offline
See [url]www.myzagi.com.[/url] All the info you need.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU1
