P51 noses over
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> P51 noses over
Page: [1]
Login
P51 noses over - 2/16/2002 11:50:16 PM
JohnVH
Status: offline
Is this common with them? I have seen a spit do it real bad, just wondering how one would correct this, if there is a way. Take off is not a big deal but landing if your not ready it goes over, especially dead stick.
PS, I believe its a dynaflite kit? with a .75
_____________________________
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 1
Nose Over - 2/17/2002 1:43:58 AM
Auger Din
Status: offline
Interesting question.
My instructor has been telling me of the same problem that he's had on different planes.
According to him, the best fixes come when building, such as moving the gear forward in the wing a tad. He said that this largely cured the constant problem in a Corsair that he built.
Apparently it went into a tumble on landing and shattered both wings. Upon rebuilding them he nudged the landing gear forward in the panels. He said that he also toed the wheels in a degree or two.
Another fix that he gave me was to replace the scale wheels with larger diameter ones.
Though, if your using retracts your problably out of luck with these. As rearranging the stuff in the wing would be a real hassle
If you woke up breathing, congratulations. You have another chance.
(in reply to JohnVH)
       Post #: 2
P51 noses over - 2/17/2002 2:55:14 AM
JohnVH
Status: offline
It has mechanical retracts.
       Post #: 3
P51 noses over - 2/17/2002 3:34:44 AM
mglavin
Status: offline
I am assuming the "CG" is close? A .75 is a bit large for this model but doable...
Is there down trim dialed into make the model fly straight and level?
Is the gear angled/tilted forward? Should be...
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
       Post #: 4
Gear angle - 2/17/2002 4:34:50 AM
L454S
Status: offline
Just shim the back side mount on the retracts till the axle is almost under the leading edge of the wing. The gear will still go back in the same hole.
From the swamp, Lenny ....Bayou Boys R/C
http://www.eatel.net/~l454s
       Post #: 5
P51 noses over - 2/17/2002 5:00:27 AM
JohnVH
Status: offline
OK, will give it a try!
I think the CG is close, I didnt get a manual, its just a hair behind the spar right now.
       Post #: 6
Nose Over - 2/18/2002 12:08:44 AM
sproosemoose
Status: offline
I had the same problem with my sureflite p40 and my 20 size p51. All warbirds have a tendency to nose over, just because of their layout. Most of the full scale warbirds were tailheavy, so if the gear is in a scale position it's difficult to keep them from nosing over. You also have to remember that the bumps on the runway are much bigger in relation to models than to full scales, so there's another problem. Bigger wheels help (ultimately saved my mustang and P40) but with retracts that may not be possible. Shimming the backside of the gear is difinitely a good idea, and remember to hold full up elevator to taxi and to gradually reduce as you pick up speed so you don't lift off too soon. Hope this helps!
sproosemoose
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
8.266RCU1
