Zen G26 wont take full throttle...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Zen G26 wont take full throttle... Page: [1]
Login
Zen G26 wont take full throttle... - 3/15/2007 8:18:39 AM
Hutch-e-bee
Status: offline
Was running my car yesterday when I noticed it getting slower and slower till eventually it died. Now it starts but wont take full throttle. If I part throttle it, it will accelerate but give it full throttle and it bogs down. Low speed screw is just over 1 turn high speed is just below 1 and a half turns. I have tried adjusting both screws in both directions but it only makes it worse. The engine hasnt done 1 gallon yet from new.
Any ideas??
       Post #: 1
RE: Zen G26 wont take full throttle... - 3/15/2007 9:10:43 AM
hathi
Status: offline
check spark plug? Color?
What car is this in and what motor?
Is the air filter clean?
With is cutting out at full throtle, tells me that it has nothing to do with the low screw. I'd try and richen out the high screw a tiny bit at a time.
_____________________________
dont run any parts on any of rc's
(in reply to Hutch-e-bee)
       Post #: 2
RE: Zen G26 wont take full throttle... - 3/15/2007 11:31:30 AM
borley1863
Status: offline
Could also be something loose or maybe a gasket has gone see if theres any leaks or manifold/exhaust has come loose.
Guy
(in reply to hathi)
       Post #: 3
RE: Zen G26 wont take full throttle... - 3/15/2007 12:21:17 PM
Hutch-e-bee
Status: offline
Just remembered I had a similar problem with an old Fiat 127 I had years ago. Part throttle fine full throttle bog down. Turned out to be dirt in the carb main jet. Gonna strip it down and clean it and check all above suggestions. Will post findings. Thanks.
(in reply to borley1863)
       Post #: 4
RE: Zen G26 wont take full throttle... - 3/15/2007 3:14:06 PM
huw4027
Status: offline
Richen the high speed needle and see what happens.
R/C IS GOOD, CLEAN FUN !!! - Too much to list !!
1/18,1/16,1/10,1/8 & 1/5 scales-nitro,gas & electric.
       Post #: 5
RE: Zen G26 wont take full throttle... - 3/15/2007 3:41:13 PM
Hutch-e-bee
Status: offline
Foreign matter in the tank!! Slighly loose carb. After fixing those it ran but still not properly, it would take full throttle but die when the throttle was released. Tried a another plug and it is A.O.K!!
(in reply to huw4027)
       Post #: 6
RE: Zen G26 wont take full throttle... - 3/16/2007 2:56:16 PM
huw4027
Status: offline
Now take her out and make up for the time that you lost.
       Post #: 7
RE: Zen G26 wont take full throttle... - 3/16/2007 3:18:45 PM
Hutch-e-bee
Status: offline
Dont worry 'bout that! I made that ass pay for holdin' out on me!
       Post #: 8
RE: Zen G26 wont take full throttle... - 3/17/2007 6:34:37 AM
Earth Surfer
Status: offline
The first thing to do is check the plug. You will find out the spark plug can give you great indicators on how the engine is running.
Go RC---Because you really can't learn much from throwing a ball around.
       Post #: 9
RE: Zen G26 wont take full throttle... - 3/17/2007 10:12:35 PM
Hutch-e-bee
Status: offline
On my nitro if i have a problem like this the first thing I check is the plug, but I just assumed as I havent had a gallon through this motor yet that the plug must be ok. It looked fine when I took it out but I swapped it anyway just to eliminate it from my search. Turned out to be part of the problem!
(in reply to Earth Surfer)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU5
