RE: Welcome Exceed RC
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Exceed RC Support - Nitro Cars >> RE: Welcome Exceed RC
Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
RE: Welcome Exceed RC - 11/21/2007 1:33:28 AM
dominicevans
Status: offline
hello....do u guys think the traxxas 2.8" wheels(like on the jato) will fit on my exceed nitro buggy?
_____________________________
speed is all I need
(in reply to HimotoRacingUSA)
       Post #: 26
RE: Welcome Exceed RC - 11/21/2007 1:52:28 AM
pede_187
Status: offline
I think they are both 12mm hex so they should.
(in reply to dominicevans)
       Post #: 27
RE: Welcome Exceed RC - 11/21/2007 1:56:50 AM
dominicevans
Status: offline
kk cuz they look cooler to me..think i'm goin to buy sum
speed is all I need
       Post #: 28
RE: Welcome Exceed RC - 11/21/2007 1:57:19 AM
HimotoRacingUSA
Status: offline
quote:
ORIGINAL: dominicevans
they will, make sure they are rears, but it will take alot away from your low end power with bigger rims and tires.
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
       Post #: 29
RE: Welcome Exceed RC - 11/22/2007 11:45:38 PM
dominicevans
Status: offline
wow wooow dis car is crazy fast faster than i thought wow and it is still sort of rich....I haven't even set the 2 speed and still it super fast
speed is all I need
       Post #: 30
RE: Welcome Exceed RC - 11/24/2007 2:39:47 AM
dominicevans
Status: offline
how do i adjust the shocks so that it the underneath doesn't hit the ground when forced is applied and where is the screws to adjust for the 2speed transmission ???
speed is all I need
       Post #: 31
RE: Welcome Exceed RC - 11/24/2007 2:47:34 AM
HimotoRacingUSA
Status: offline
i am not sure what shocks you have but you either put the spacers above the spring that came with the car or you adjust the spring with a round nut on the threads on the top of the shock.
there is a grub screw on the 2 speed shifter in front of the spur gears on the trans, you see it from the bottom of the car, its a silver disk in front of the 2 spur gears, there are 2 grub screws, one holds the shifter on the shaft the other adjusts the shift time, you can tell if its hard to move, its the wrong one. be careful not to adjust it too lose other wise the screw will fall out. Clockwise makes it shift at higher rpms and counterclockwise makes it shift at lower rpms. Do 1/2 turns at a time and try.
       Post #: 32
RE: Welcome Exceed RC - 11/24/2007 2:49:59 AM
Macanan
Status: offline
Go here a little over half way down the page someone explains how to do it with pictures
http://www.rcuniverse.com/forum/m_4207842/anchors_4207842/mpage_1/key_2nd%252Cgear%252Cshift/anchor/tm.htm#4207842
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
       Post #: 33
RE: Welcome Exceed RC - 11/24/2007 2:51:22 AM
dominicevans
Status: offline
ok i will try that 2morrow......oh and i was talking about the ball screw at the top of the shocks, i want to know how to get it into a lower whole
speed is all I need
       Post #: 34
RE: Welcome Exceed RC - 11/24/2007 4:12:59 PM
dominicevans
Status: offline
what tool do i loosen the grub screw with??
speed is all I need
       Post #: 35
RE: Welcome Exceed RC - 11/24/2007 4:47:18 PM
Macanan
Status: offline
a hex key/allen wrench
< Message edited by Macanan -- 11/24/2007 4:48:45 PM >
       Post #: 36
RE: Welcome Exceed RC - 11/25/2007 3:47:32 AM
HimotoRacingUSA
Status: offline
1.5 i think, its a small one
(in reply to Macanan)
       Post #: 37
RE: Welcome Exceed RC - 11/25/2007 3:59:11 PM
dominicevans
Status: offline
ok dat didn't really work
and den the screw and the spring came out and i can't get them back in, is the anything else other than spring that should come out it when the screw comes out?
speed is all I need
       Post #: 38
RE: Welcome Exceed RC - 11/25/2007 5:54:59 PM
Macanan
Status: offline
You can get a new one from here for $3.50
http://www.clermontmotorsports.com/servlet/the-125/2-Way-Drive-Clutch/Detail
       Post #: 39
RE: Welcome Exceed RC - 11/25/2007 6:36:05 PM
dominicevans
Status: offline
so once the screw and the spring comes out i can't put them back in?
speed is all I need
