devens
IL, USA Status: offline
Well I have made the conversion to all new electronics and I am having problems. Here are my specs transmitter: JR 7202 synth receiver: JR RS6UL 6 channel micro ppm servos: stock Gyro: Align RCE-500X (was going to use the e-flite G-90 but decided on what was available, they are nearly the same gyro) Main motor stock main ESC GWS ICS300Li (temporary until my electrifly C-25 comes in) tail motor stock tail ESC electrifly C-12 (middle receiver wire disconnected) battery electrifly power series 3S, 20C, 11.1V, 640mA (this is just to start off with, I know guys are using higher mA) channel assignment: 1-main ESC 2-Aile 3-elev 4-tail ESC 5-gain 6-collective radio setup 3 servo 120deg ccpm swash gear channel (5): set to gear Aux2: INH My problem is that when I move the throttle/collective stick up just the collective works. Then after a few seconds all the servos start to glich severly. I have tried 2 identical receivers I have tried to substitute the original speed control as per HeliMax instruction. I have the three ccpm servos working fine until I move the throttle. This happens with or without the gyro pluged in. I haven't tried a totally different type of receiver. That micro 6CH might not be capable for some reason. other than that I am at a dead end
< Message edited by devens -- 8/1/2007 1:55:36 AM >
_____________________________
Corsair Brother #2, Waco Brother #80 AMA#497873 Member; Decatur Aero Commanders
