dreimer
WA, USA Status: offline
quote:
ORIGINAL: dreimer OK....kind of off topic, but here goes... I replaced the tail boom with the needle...works GREAT! And for $2.88, it beats the official replacement. I also at the same time replaced the swash and blade grips (previously broken) with CNC parts from HeliDirect (Microheli). Now the darned thing won't lift off the ground...even at full throttle, and Idle-Up ON...it get's to a point in the trottle, and kinda jumps like it's going to lift off, but it's just a small jump...it never gets more than an inch off the ground, and only then for just a second. I've set all of the linkages to factory, pitch gauged, and it all looks good...it just doesn't want to lift...Is this a bad servo, rcvr? None of the servos seem to jump, or lag? Long story about this now. I emailed Helimax (Hobbico), and they said to adjust the pitch more. I did, and now I think the 3-n-1 or the ESC is fried now, as the freshly charged (11.2 VDC) battery, will not even spin the blades. Also the furthest back servo is way out of whack, going there right after the battery is plugged in. This leads me to believe that it is NOT a servo. HeliMax wants me to send the whole thing back, and let them repair/test fly, or replace. What do you guys think?
