guver
OH, USA Status: offline
Wow, those are expensive. Ok, that settles it for me. Since I am not interested in "owning" any of them , lets go for your original idea of shipping and see what you think of this. If you'd rather PM that's fine too. Send me 1 stick pack and I'll test it at the highest current I can (my standard is 10 amps) and can overlay some of my graphs of various 6 cell batts. I can then test at my max current of about 15 amps. I will then test each "stick" of 3 cells at the max current of about 30 (CBA max is 40 and I'll try to get to the 38 amps without breaking apart the cells anymore) I won't break apart the cells that are all spot welded together, but will probably have to remove the shrink wrap and either solder to or just replace the bottom (end) battery thin strap with a regular battery bar. If all the cells make it thru all the testing without getting hurt then when I get done I'll shrink wrap it with the heavy duty battery bar at the end and you may get back a better battery than you started with. It will have some heavy cycles on it, but hopefully will take it. If this sounds good then please e-mail me and I'll send you my shipping address.
_____________________________
This is an apostrophe ''
