RE: Got it running again but....    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Got it running again but....
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Got it running again but.... - 3/20/2007 9:48 PM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
Andy, you may have a blown engine, if it ran for 3 minutes at WOT and you were just breaking it in, it probably overheated and blew the engine, that would explain why your having a hard time.
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to MiniCwik)
       Post #: 26
RE: Got it running again but.... - 3/20/2007 10:20 PM
Andyde4
Score: 100
Last Login: 10/28/2012
Status: offline
If it was blown would it run for a second then shut off like it does?
Torando XP
Hide Signatures
(in reply to ehroof)
       Post #: 27
RE: Got it running again but.... - 3/20/2007 10:37 PM
MiniCwik
Score: 100
Last Login: 4/22/2010
Status: offline
I wouldn't think so ... but ehroof does know his stuff.
Can you start it and let it idle?
Or, does it immediately increase RPM's on its own?
Nitro Trk - Himoto Eldorada 1:10 4WD (w/bling)
EP Helis - T-Rex 500 CF (401/9257) & 450 SE V2 (Scorpion -8V2/401/9257)
Hide Signatures
(in reply to Andyde4)
       Post #: 28
RE: Got it running again but.... - 3/20/2007 11:10 PM
Andyde4
Score: 100
Status: offline
I have actually fixed that it doesnt want to take off like it did it will idle for a couple seconds then shut off.The motor was already broken in when i had the problem before i had crashed it and I had to rebuild the whole car so i was just checking it all over when it ran WOT for three minutes. I just took these pics. I am working on uploading the Video I just took
Click to see fullsize image.
Click for fullsize
Click for fullsize
Torando XP
Hide Signatures
       Post #: 29
RE: Got it running again but.... - 3/20/2007 11:13 PM
Andyde4
Score: 100
Status: offline
This is the video
http://www.youtube.com/watch?v=_SYrWREIF5s
Torando XP
Hide Signatures
       Post #: 30
RE: Got it running again but.... - 3/20/2007 11:14 PM
MiniCwik
Score: 100
Status: offline
Can you use the "macro" button or mode on your camera? It works wonders when taking photos of still objects up close and removes the fuzziness.
But from what I can see, I do not see a problem ... how's your idle screw, can you get an angle shot showing that too?
Hide Signatures
       Post #: 31
RE: Got it running again but.... - 3/20/2007 11:17 PM
MiniCwik
Score: 100
Status: offline
Saw the vid, when it died there did you hit the brake?
How about if you leave the glow charger on a little bit? I have to do that from time to time due to temps here not being as warm as I'd like.
And you did check to see that the glow plug stays lit when you remove it and put it in the igniter/charger, right?
Hide Signatures
       Post #: 32
RE: Got it running again but.... - 3/20/2007 11:21 PM
Andyde4
Score: 100
Status: offline
No i didnt hit the brake or nothing let me go out and take acouple more pics and ill try to leave the charger on alittte longer
Torando XP
Hide Signatures
       Post #: 33
RE: Got it running again but.... - 3/20/2007 11:30 PM
MiniCwik
Score: 100
Status: offline
Yeah, I would ... I have to on mine with it being below 50. The other day when it was 73, I didn't have that problem.
Hide Signatures
       Post #: 34
RE: Got it running again but.... - 3/20/2007 11:31 PM
Andyde4
Score: 100
Status: offline
ok I left the charger in longer and it did the same thing.Your right that mode on the camera works good here are some more pics
Click for fullsize
Click for fullsize
Click for fullsize
Torando XP
Hide Signatures
       Post #: 35
RE: Got it running again but.... - 3/20/2007 11:39 PM
MiniCwik
Score: 100
Status: offline
Okay, and yeah those pics are better, although dark (got flash? lol)
Tighten up that thumbscrew at the end of the brake some more ... it looks like that lever going into the cam has lots of play in it. Mine there is little to no play at all.
Bring your low speed needle out more, it's almost flush but not quite, at least to my eye.
It looks like your idle position is not all the way back on the throttle lever (black boot), mine sits back further.
Remove and clean that air filter, while removed snap another pic of your carb opening.
Is your header loose at the manifold/engine? Check that too ...
Uploaded your pics after altering the contrast to see things.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 36
RE: Got it running again but.... - 3/21/2007 7:43 AM
Andyde4
Score: 100
Status: offline
Still nothing.Anyone want to buy a junk Torando XP? lol
Torando XP
Hide Signatures
       Post #: 37
RE: Got it running again but.... - 3/21/2007 8:15 AM
bluecaka69
Score: 100
Last Login: 8/6/2012
Status: offline
check your glow plug itself it may be going bad pull it out and put it in ignitor it should glow bright redish orange
Bodies By Blue-Airbrushes Bring Out The Artist In All Of Us!!
All About Fun Hobbies
Hide Signatures
       Post #: 38
RE: Got it running again but.... - 3/21/2007 3:02 PM
MiniCwik
Score: 100
Status: offline
Yeah, that is what I have been saying ...
Also, remove air filter and clean it, while it's removed snap a picture of the carb opening, I'd like to see how open it is.
Hide Signatures
(in reply to bluecaka69)
       Post #: 39
RE: Got it running again but.... - 3/21/2007 10:56 PM
ehroof
Score: 105
Status: offline
i told him about the plug, he said he changed it, it sounded like a plug to me too. Andy leave the ignitor on it when your running it and see if it stays running then
Hide Signatures
       Post #: 40
RE: Got it running again but.... - 3/22/2007 2:59 AM
Andyde4
Score: 100
Status: offline
Good news I think I tired to get it started and he started and ran for a good 45 seconds before it shut up.The brakes worked and everything.So after it shut off I tired to get ti started again but it wouldnt I had to prime it agian and then it ran for less time.Heres the picture of the carb opening.Sorry about it being blurry
Click for fullsize
Torando XP
Hide Signatures
       Post #: 41
RE: Got it running again but.... - 3/22/2007 4:58 AM
MiniCwik
Score: 100
Status: offline
Cool!
Was that with the glow igniter attached?
Take the glow plug out and put it in the igniter and see if it STAYS bright orange the entire time? Does it?
Hide Signatures
       Post #: 42
RE: Got it running again but.... - 3/22/2007 5:06 AM
Andyde4
Score: 100
Status: offline
Yeah it styas bright orange I checked that
Torando XP
Hide Signatures
       Post #: 43
RE: Got it running again but.... - 3/22/2007 5:16 AM
ehroof
Score: 105
Status: offline
it must be a fuel problem, something to do with not getting fuel or a hole in the fuel/exhaust line. i had a crack in my fuel tank and it wouldt run good and i had a crack in my line that goes from the exhaust to the tank. check these out. or your high speed needle is clogged. make sure its cleaned out.
Hide Signatures
       Post #: 44
RE: Got it running again but.... - 3/22/2007 6:07 AM
glk420247
Score: 100
Last Login: 5/10/2012
Status: offline
Recently I had a problem with mine not idling very well and hard to start. I found that the carburetor was coming loose. I took it apart and had to re-position the o-rings, then put a littler permatex on it. Now it is running like a champ. Air leaks are a ****.
Team Losi Lst2 (Kick azz truck)
Hide Signatures
       Post #: 45
RE: Got it running again but.... - 3/22/2007 9:25 AM
RoadBurner
Score: 100
Last Login: 8/6/2008
Status: offline
Its sounds like the fuel is not being pulled in properly..... in comparison to pinching the fuel line to shut off. Having to prime it after it runs is another indicator of bad suction! I would pull the carb off and make sure it is sealing tight! It sounds as if it is only running off the fuel from priming!
< Message edited by RoadBurner -- 3/22/2007 9:27 AM >
Hurricane XP Pro, Avalanche
My Hurricane has wings!!!
Hide Signatures
(in reply to glk420247)
       Post #: 46
RE: Got it running again but.... - 3/23/2007 4:24 AM
Andyde4
Score: 100
Status: offline
I unscrewed the needle all the away and then screwed it back in and it started to move gas again.So I primed it and got it running.It would run and I could give it gas and it would go and i could give it alittle and it would stop.But as soon as i let off the brake it would go again.It wouldnt really idle.If i gave it full brake it would shut off.I have done adjusted everything on it is there anything else that might be wrong or an adjustment i could do.Im still learning on these things and I have ran out of ideas lol. I have a video of this I dont know If it helps.
http://www.youtube.com/watch?v=Bl_Ps6BVXk4
Torando XP
Hide Signatures
(in reply to RoadBurner)
       Post #: 47
RE: Got it running again but.... - 3/23/2007 4:37 AM
ehroof
Score: 105
Status: offline
you need to tune it better and adjust your linkage
Hide Signatures
       Post #: 48
RE: Got it running again but.... - 3/23/2007 4:40 AM
Andyde4
Score: 100
Status: offline
Which Linkage?
Torando XP
Hide Signatures
       Post #: 49
RE: Got it running again but.... - 3/23/2007 4:46 AM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
Your idle is way to high also. Put up your antenna also.
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
