JEFFRO503
OR, USA Status: offline
Awesome..thanks guys! So if i have this right , i need to buy two sets of header's (one for a DA 100 and a set for the BME 115) , splice the BME exaust brackets off of the BME pipes , and then hook them up to the DA pipes.......is this correct? Also MRT1750....in your pictures , you have your pipes spliced together with what? I see a set of coupler's on there , but what is the other "wrap type stuff"? And will it hold up to vibration well? Also.....I want to see if i have this right. The BME header's , put the two cans too close together ( as in the sides of the cans are rubbing against each other) is this correct? I guess the angle after it comes off the exaust port is wrong for this plane......is that right? If i had someone who could braze them back together , i wonder if that would hold? Or maybe the coupling idea you have in your pictures is a better way.......more flex and welds won't break. before i get to carried away here , i am going to write Tom and see if he has this Sukoi in stock , if so , i'm ordering one up within the next few days i think.
