3dmadman
Joined: 9/3/2004 From: Austin, TX, USA Status: offline
The test flight was a complete success. The thing flies exactly like its electric prototype, the "32 Special" except in the sheer power department ( as I suspected after beginning construction...). The little Saito 30 just about neutralizes the weight of the plane, but it is still quite new and clearly needs to be dialed in. Even so... the Saito 56 or a 40 2 stroke is what this baby wants for hovering power. I only got about 5 or 6 minutes total time tonight. I guess I expected this little 30 to run as good as my 3 year old Saito .91. Tomorrow is another day. Oh, talk about thrust angles and pulling, ect... I set the CG on the 44 identicle to that of the electric prototype and as soon as i got it into the air, I said "too light in the nose", because of climbing when I opened the throttle, but, 4 minutes and 4 oz of fuel later, the first landing was a perfect 3 pointer, one of my best landings ever, and still needed slight back stick, so the CG is fine, I need down thrust. Everything is set at zero, zero, zero right now. So is my electric but IT dont pull up quite as much, but it does pull up slightly when you quickly flip the throttle to full and I like that because the thing SNAPS into a hover so fast you can hardly see the transition when you pull back hard and flip open the throttle. OK gotta go clean her up. Tell me how your flight went. J.D.
