RE: OMP Fusion Picture Gallery
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> RE: OMP Fusion Picture Gallery
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: OMP Fusion Picture Gallery - 8/19/2007 3:50 AM
Futaba Owner
Score: 100
Last Login: 4/30/2009
Status: offline
I'm not to familiar with all the coverings, so has anybody had problems with the china kote on the fusions?
Hide Signatures
(in reply to AFSalmon)
       Post #: 26
RE: OMP Fusion Picture Gallery - 8/20/2007 1:41 PM
AFSalmon
Score: 100
Last Login: 11/6/2009
Status: offline
As with any ARF is is a good idea to go over allthe covering with medium heat when you first start. The Fusions are no different. Go over all the edges of the covering with your covering iron and medium heat. Any loose edges of covering can be tacked down with trim solvent or even thin ca if you know how to use. I did all this even on my 35% aeroworks yak.
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to Futaba Owner)
       Post #: 27
RE: OMP Fusion Picture Gallery - 8/20/2007 2:42 PM
geh3
Score: 100
Last Login: 11/7/2009
Status: offline
I notice that there is a differnce between the ARF fusion and the Kit FUSION in regards to the number and placement of hinges( the kit has more) should the arf be upgraded to the # called for in the kit?
Hide Signatures
       Post #: 28
RE: OMP Fusion Picture Gallery - 8/21/2007 1:01 PM
AFSalmon
Score: 100
Status: offline
The ARF has plenty of hinges and we haven't had any issues with the hinges. Hinging is one of those personal preferences on models - folks tend to do hinges they way they like to do them. Some folks use a lot of CA hinges and others like point hinges such as Dubros.
Ohio Model Planes
Hide Signatures
(in reply to geh3)
       Post #: 29
RE: OMP Fusion Picture Gallery - 9/8/2007 8:40 PM
daveopam
Score: 109
Status: offline
Mike if I order a Fusion 90 as of right now will it be Ultra Cote? I love my 52" Fusion ARF but will need to recover it. I don't want the 90 size to be the same way.
David
"Never use a big word when a little filthy one will do"
Johnny Carson
Hide Signatures
       Post #: 30
RE: OMP Fusion Picture Gallery - 10/24/2007 9:13 PM
daveopam
Score: 109
Status: offline
Sorry to double post if you guys saw my other thread. I am just so happy with how my 52" came out. I wanted all to see it.
Bottom is 2"x2" Ultracote. Rest is Monocote. Metalic green,yellow,white and red.
David
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Johnny Carson
Hide Signatures
(in reply to daveopam)
       Post #: 31
RE: OMP Fusion Picture Gallery - 10/24/2007 9:26 PM
exeter_acres
Score: 105
Status: offline
My 40%Carden Extra 330 and my Fusion........
Click for fullsize
Extreme Flight RC tech support
"Some are born great, some achieve greatness, and some hire PR officers."
Hide Signatures
       Post #: 32
RE: OMP Fusion Picture Gallery - 10/24/2007 11:50 PM
AFSalmon
Score: 100
Status: offline
SCHWEEEEETT!
Ohio Model Planes
Hide Signatures
(in reply to exeter_acres)
       Post #: 33
RE: OMP Fusion Picture Gallery - 11/8/2007 4:25 AM
alqwad
Score: 100
Last Login: 10/27/2009
Status: offline
Here's mine... Began it's life as a white ARF that I got from y'all a few months ago while they were on sale. Maidened today. Flies great. Got about 4 tanks run through it. Saito 82 for power. Great knife edge and KE spins. On final flight for the day, I noticed the gear was lagging toward the rear of the plane a bit. Flew it around the pattern a few times and decided it was just an optical illusion... NO. It was obvious that the top LG bolt had fallen out when the gear "retracted" to the leading edge of the wing on my otherwise smooth landing. Gear just neatly folded back with no damage whatsoever. My mistake for not tightening, I guess. It was actually pretty funny. Unfortunately, no one was there to witness. Again, very good plane. I think I might try an Edge kit...
Click for fullsize
< Message edited by alqwad -- 11/8/2007 4:30 AM >
MIGJAM
Hide Signatures
       Post #: 34
RE: OMP Fusion Picture Gallery - 11/8/2007 12:56 PM
AFSalmon
Score: 100
Status: offline
I like the blue prop spinner---Nice touch. Put some graphics here and there and that would really dress it up.
Ohio Model Planes
Hide Signatures
(in reply to alqwad)
       Post #: 35
RE: OMP Fusion Picture Gallery - 11/8/2007 3:45 PM
alqwad
Score: 100
Status: offline
Thanks Mike... I have a question for you with the 40 size tetherite gear. I have one that a friend gave me a while back. The mounting holes are drilled 1 1/8" center to center. Is this the same as the newer ones that you guys carry or are they drilled to bolt right up to the ARF 's pre drilled location, which is a bit larger? Thanks.
MIGJAM
Hide Signatures
       Post #: 36
RE: OMP Fusion Picture Gallery - 11/24/2007 9:10 PM
daveopam
Score: 109
Status: offline
The Tetherite I bought was not drilled. Great covering job. I like the way you did not wrap the black over the top. I never thought about doing it like that.
David
Johnny Carson
Hide Signatures
       Post #: 37
RE: OMP Fusion Picture Gallery - 11/25/2007 2:38 AM
alqwad
Score: 100
Status: offline
Thanks for the compliments Dave... I'm not much of a covering guy; I don't have much experience and I'm not that good at it. Thanks again.
MIGJAM
Hide Signatures
       Post #: 38
RE: OMP Fusion Picture Gallery - 11/25/2007 5:05 PM
daveopam
Score: 109
Status: offline
I think you will find that on most covering jobs the defects can only be found by the installer.
David
Johnny Carson
Hide Signatures
       Post #: 39
RE: OMP Fusion Picture Gallery - 11/25/2007 7:13 PM
eyalbartfeld
Score: 100
Last Login: 10/9/2009
Status: offline
Here are some pics of a Fusion-90, built from a kit. Note the 'bud' muffler. (Location: Boston area, look at the foliage in the background)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 40
RE: OMP Fusion Picture Gallery - 11/26/2007 1:10 AM
John Wells
Score: 100
Status: offline
Here are a couple of my Fusion 90 ARF with YS 110.
Fusions ROCK!!
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to eyalbartfeld)
       Post #: 41
RE: OMP Fusion Picture Gallery - 12/18/2007 5:38 PM
MIXMASTER
Score: 100
Last Login: 9/23/2009
Status: offline
Love the ARF's that come with Mono/Ultra cote, hate that China-crap stuff. You know its going to be bad when the covering falls off just handling the parts. The adhesive separates from the film in the worse way, in a spotty way, then you cant get it heated back down in exactly the same position. I had to use packing tape to seal the edges in that spot, nothing to hold anymore, not even finished building yet!
Jimmy touch tail & I dont care!!!
Hide Signatures
(in reply to John Wells)
       Post #: 42
RE: OMP Fusion Picture Gallery - 12/18/2007 6:18 PM
AFSalmon
Score: 100
Status: offline
quote:
ORIGINAL: eyalbartfeld
Love the bud pipe. I have not seen that particuliar can. I have several myself including a nice looking orange fall theme bud can. I'm saving that one for a future plane.
Ohio Model Planes
Hide Signatures
       Post #: 43
RE: OMP Fusion Picture Gallery - 12/26/2007 8:38 PM
bodman
Score: 100
Last Login: 11/5/2009
Status: offline
I bought a white Fusion with the china cote covering. The covering looks good at first, but it seemed very brittle and the clear seperates from the white when you pull it loose. I used a heat gun to warm up the covering and then pulled it off. Some of the white stayed on, but I used laquer thinner to clean off the white. I am going back with Ultra Cote.
Hide Signatures
       Post #: 44
RE: OMP Fusion Picture Gallery - 12/27/2007 12:15 AM
daveopam
Score: 109
Status: offline
bodman, you can also use Trim Solvent if you have some.
David
Johnny Carson
Hide Signatures
(in reply to bodman)
       Post #: 45
RE: OMP Fusion Picture Gallery - 12/29/2007 1:27 AM
bodman
Score: 100
Status: offline
David,
Thanks, I run a body shop, laquer thinner is always on hand. Fusion looks to be a good plane. I have a Mvvs 91 to put on it.
Hide Signatures
       Post #: 46
RE: OMP Fusion Picture Gallery - 1/3/2008 11:56 PM
John Wells
Score: 100
Status: offline
Here's the way to deal with the chinakote and it works. Clean your covering with Windex and paper towels (no remaining oil film!). Easier to do this to a new Fusion with no oil residue.
Next, detail the covering with a warm to medium, not hot iron. When you get it all tightened up and the edges ironed down, do this;
Spray some clear Lusterkote (can spray) into the can lid. Wait a minute or so for the tiny aerosol bubbles to dissipate from the liquid. Use a small brush to apply a thin bead of the liquid Lusterkote to the covering seams (where the color meets the white). I did my entire Fusion 90 in about 45 minutes.
Let the stuff dry overnight and guys, your Fusion covering will not be an issue anymore.
Hide Signatures
       Post #: 47
RE: OMP Fusion Picture Gallery - 1/6/2008 7:16 PM
Tango Juliet
Score: 100
Last Login: 11/3/2009
Status: offline
I wish I had seen this earlier, I just ordered the large Fusion ARF in all White. If the "China"Kote is that bad, how hard would it be to just remove it from the beginning and replace it with something of a better quality? Obviously one buys a precovered ARF in an effort to avoid this, but ARC's don't seem to exist anymore, and if I'll need to recover it eventually anyway, I may as well do it now right?
AMA#: 741093 Member: Azalea City Model Aeronautics (www.acma-rc.com)
Hide Signatures
       Post #: 48
RE: OMP Fusion Picture Gallery - 1/6/2008 7:30 PM
Tango Juliet
Score: 100
Status: offline
One other Question: What's everyone using for power?
Hide Signatures
(in reply to Tango Juliet)
       Post #: 49
RE: OMP Fusion Picture Gallery - 1/6/2008 8:46 PM
alqwad
Score: 100
Status: offline
Most 4 stroke users are going with Saito 72 or 82. Best power to weight ratio out there... 2 strokes that seem popular are the OS 46AX and 55AX. Engine prefrence runs a plenty. Good luck.
MIGJAM
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.250RCU1
