jsm77777
NC, USA Status: offline
I flew my 35% 260 today. It turned out to be pretty windy with winds 10-20mph, but I got in 7, 11 minute flights. Plane flies well. It did need a few clicks of aileron correction, and 1 click of up. I think the incidence is slightly off on the wings, but no big deal. It requires very little mixing, and right now I am only at 5% elevator with rudder. It was hard to get it perfectly dialed in with the wind, but it's close. With the DA-100, it has plenty of power. After flying the plane, I think I could use around 3-4 ounces of weight in the tail to be perfect. It still flies well as it is. A DA-85 might be a perfect choice for less nose weight, and it should have plenty of power. I still prefer the twin, so I'll stick with the 100. In high alpha, there is very little wing rocking. Waterfall's, blenders, harrier's are great, and it does beautiful inverted flat spins, and knife edge spins. Very hard plane to beat that will fly precision, and 3D this well. I did gap seal my elevators, and I only need 28% of throw to fly any sequence. That elevator is powerful. It does need 2 5955 servo's for the rudder if you want to do knife edge loops with the 100 in front. I am only getting about 50 degrees of throw on my rudder with the servo arms I'm using, and it will knife edge loop well. It would be better with the tail weight I could add, but works for now. I kept my torque rolls and high alpha rolling manuevers brief, since I am still breaking in the engine. The plane torque rolls well, and I was surprised since I'm a little nose heavy. In short, just a nice flying plane. I can't wait to get the 100 broken in and switch to Amsoil 100-1. I don't like the mess with 32-1. Scott
